battery draining question- honda cb360t
Discussion in 'Motorcycle Technical Discussion' started by wallster, Sep 8, 2004.
  1. wallster
    wallster Guest
    I have a stripped down honda cb360t (1976) that's used for trail riding.
    There are no lights or turn signals on it. (there is a horn) anywho, when
    the key switch is turned on (and the kill switch on the handlebars is on)
    the battery voltage drops steadily, like there is a draw on it. When I turn
    the switch off, the battery goes back up to around 12 volts. The bike kick
    starts perfectly, and when it's running, the voltage does not lower. What
    could drawing the battery? I've checked for any wires that would be grounded
    out but find nothing. It seems wierd because when started, it holds the
    voltage. Any ideas??
    thanks,
    walt
  2. wallster
    Rhino Guest
    Your point ignition system draws power from the battery
    Rhino, Sep 8, 2004
  3. The ignition system.
    Next question?
    The Older Gentleman, Sep 8, 2004
  4. wallster
    wallster Guest
    thanks for all the responses. i knew the ignition draws from the battery
    when the switch is on, and because it's an old shitty battery... it all
    makes sense. i was looking for reassurance. the diodes in the rectifier
    could be a culprit as well, a new battery first though makes sense.
    thanks again,
    walt
