Beer drinking & bike fettling
Discussion in 'UK Motorcycles' started by CT, May 3, 2004.
  1. CT
    CT, May 3, 2004
  2. CT
    prawn Guest
    Good to see normal service resuming.
    prawn, May 3, 2004
  3. CT
    I've only just started hosting the site and it's still W2K Pro
    so limited to 10 connections. I'll upgrade eventually.
    It's brightening up here. I'm still more likely to go to the
    pub rather than get the bike out, mind.
    CT, May 3, 2004
  4. CT
    Tim Guest
    I say old chap, the pic "Ginge threatens TOG" (#42), happens to show my
    back. I am not sure whether you are insulting TOG or myself :)
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm2 at dsl dot pipex dot com
    Tim, May 3, 2004
  5. CT
    Well, get your fucking hair cut then :eek:)
    <fx:whistles & toddles off to web server>
    CT, May 3, 2004
  6. CT
    Tim Guest
    Git ;-P
    Tim, May 3, 2004
  7. CT
    Ben Blaney Guest
    Fucking hell, how high are your ceilings?
    Ben Blaney, May 3, 2004
  8. CT
    platypus, May 3, 2004
  9. Paul Corfield, May 3, 2004
  10. CT
    Verdigris Guest
    How low are your ceilings that you[1] could manage without?
    [1] Stumpy.
    Verdigris, May 3, 2004
  11. CT
    Nigel Eaton Guest
    Nigel Eaton, May 3, 2004
  12. CT
    Ben Blaney Guest
    Dunno. Normal height, I suppose. Just stood with my arm extended, I
    could paint my ceilings with a normal roller quite comfortably.
    Ben Blaney, May 4, 2004
  13. CT
    For most of the rooms in my place, I need to be on about the 3rd step
    of my 7-step ladder to be able to paint the ceilings with a normal
    ladder. For the two front rooms on the ground floor it'd be more like
    the 4th or 5th step (these rooms are >3m high).
    darsy, May 4, 2004
  14. CT
    Ben Blaney Guest
    You have a nice house, and I have a poxy "Bovis home".
    I used to be able to get my car in my garage, though - so **** you.
  15. CT
    I like my current place, but the location isn't ideal - I'd much
    prefer to be - quite literally - around the corner.
    I *can* get the Jeep in the garage, but it takes about 5 minutes, and
    not at the same time as the bike(s).
    Which is why we're going to buy some sort of noddy car to do us until
    we next move.
    darsy, May 4, 2004
