Beloved BM
Discussion in 'UK Motorcycles' started by Howard, Jan 11, 2008.
  1. Howard
    Howard Guest
    decided self-immolation (that does involve fire doesn't it?)
    would be a good idea this morning with smoke pouring from
    under the tank.
    I deprived it of the necessary current and it quietened down.
    Tank off to see what's upsetting the thing and I discover
    that fat bastard of a cable from battery to inside somewhere
    very awkward to get at, has shorted itself against the frame.
    What colateral damage can I expect here? and will it be a
    bastard to fix?
  2. Howard
    Mark Olson Guest
    If the short occured from the main positive battery cable to
    the frame, before it reaches the starter relay and main fuse,
    I wouldn't expect anything other than the cable to be damaged.
    If you're cheap and don't want to replace the cable, you could
    get by with simply wrapping it up with electrical tape, and
    making sure the cable is properly routed so it won't wear
    through the insulation again.
    Mark Olson, Jan 11, 2008
  3. Howard
    Howard Guest
    That sounds promising, thanks
  4. If it has been caused by simple mechanical abrasion, then other than the
    cable itself, probably none.
    Inevitably.
    steve auvache, Jan 11, 2008
  5. Howard
    I concur with the learned gentlemen.
    Pip Luscher, Jan 11, 2008
  6. Howard
    MikeH Guest
    Slip some hosepipe over it?
    MikeH, Jan 11, 2008
  7. Howard
    boxerboy Guest
    Was the ignition off or on?
    Off - Then re route the cable and wrap all of the wires in tape and
    you should be OK
    ON - Then do the above and then turn on. Most of the time you should
    have no problem, if you are really unlucky then;
    Diode board
    Voltage regulator
    and a couple of fuses.(inside headlight)
    Timo will be along in a minute with even greater detail, Mr Longhaired
    boxhead is the font of all knowledge
    This was a common problem with a batch of boxers made at this time,
    most dealers should have picked it up by the 5,000 or 10,000 mile
    service. They had enough warnings.
    Good luck
    Boxer Boy
    BMW powered for 29 years
    boxerboy, Jan 11, 2008
  8. Howard
    Howard Guest
    I had just started the bike and looked at the exhausts to
    see where the smoke was coming from.
    It then cut out just before I switched it off.
    I'm all ears.
  9. Howard
    Sorry, no specific ideas. My first check would be to see if the damage
    to the cable looks mechanical (IOW if the insulation has worn
    through). The "wrap it in insulating tape" bit would most likely help on
    this one. If the magic smoke is still trying to escape after wrapping
    the cable then something's drawing a lot more current than it should...
    Actually I would replace the cable, mainly because I wouldn't feel
    comfortable with one that's shed its insulation - IIRC where it lives,
    it does get a lot of heat from the engine which would cause the
    insulation to age prematurely.
    Timo Geusch, Jan 11, 2008
  10. Howard
    Howard Guest
    Cheers Timo, there is a friendly boxer man near us and he's
    going to see if he has a replacement cable for me.
    Fingers crossed.
  11. Howard
    Worth checking the wires to the handlebars where they wrap around the
    headstock while you are fixing it all.
    Hog, Jan 12, 2008
  12. Howard
    Howard Guest
    Said wires appeared to be in good condition.
    New heavy cable fitted from battery to solenoid, squirt all
    connectors with AFC(?), refit tank.
    The clock ticks, good oh. Ignition on, lights show dimly on
    the dash but there's no action re the starter.
    Not even a little click.
    Fuses undamaged.
    Would the battery have been damaged/drained by its experience?
    Overnight optimate and try again tomorrow.
    Thanks all round.
    Howard, Jan 12, 2008
  13. Howard
    Throw a multimeter at the battery to be sure. If the main cable was
    welding itself to the frame, you had a lot of current flowing so I'm
    not surprised that the battery is feeling a tad weak today.
    Timo Geusch, Jan 12, 2008
  14. Howard
    Howard Guest
    Seems to be waking up already. fingers crossed.
  15. Howard
    Good.
  16. Howard
    Use it as an excuse to buy a nice Hawker Odyssey battery.
    Of course if you short that fucker out it might weld the bike to the
    planet.
    Hog, Jan 13, 2008
  17. Howard
    Howard Guest
    Like it!
    However it might not be necessary, the bike is back to life
    again.
    Phew.
    Howard, Jan 13, 2008
Similar Threads
Loading...
