Bent shift shaft - XR100
Discussion in 'Motorcycle Technical Discussion' started by Darin, Nov 25, 2003.
  1. Darin
    Darin Guest
    My buddies sons xr100 took a pretty hard t-bone early this summer and
    bent his shifting shaft. He got it bent back to where it was ridable but
    would slip out of second gear. The shaft was so bent that it wouldn't
    even come out of the cases. We cut it off flush to the case and then it
    slid out. Before we go any further on this I wanted to ask. Would the
    bent shaft, itself, cause the bike to be slipping out of second gear?
    Should there be any reason to split the cases? Our thinking was if
    something is broken or bent (shifting fork?) inside he would have heard
    or felt a vibration while riding.
    Thanks
    Darin
    Darin, Nov 25, 2003
  2. Darin
    the fly Guest
    A bent fork won't necessarily make anything vibrate. It'll
    just cause missed shifts, slipping out of gear, etc. It's probably
    worth having a look.
    the fly, Nov 26, 2003
  3. Darin
    Iowa883 Guest
    Bent shifting fork is my bet, that is if I was a gambling man :)
    Iowa883
    Iowa883, Nov 29, 2003
