Beware Elderly Corolla Drivers
Discussion in 'Australian Motorcycles' started by Chris, May 10, 2004.
  1. Can't speak for anybody else but yes I do.
    Course not.
    Chrome Don't Get You Home pepito, May 12, 2004
  2. Chris
    conehead Guest
    Bobby would.
    Conehead
    "Because they *thought* they where smart and could go fowards easily, after
    not to bad a show first year out,they perhaps have changed to much and now
    putting it all back again ?"
    Hatz, in gibberish mode, again.
    conehead, May 12, 2004
  3. Chris
    Nev.. Guest
    ....only because your VFR steers like the Queen Mary 2. :)
    Nev..
    '03 ZX12R
    Nev.., May 12, 2004
  4. Stay the hell out of my way...
    Postman Pat
    Pat Heslewood, May 12, 2004
  5. Chris
    Would it be too much to expect them to trim it occasionally?
    Knobdoodle, May 12, 2004
  6. Chris
    FuTAnT Guest
    I think I see a few too many people admiring it actually. I'm wondering how
    many idle hands it gets parked there. I saw numerous sets of people stop and
    look at it, some people even taking photos on their phone. ???
    Oct 2003, I was also the guy that parked the green 2000 ZX6R there, and the
    black '98 ZX6R, and the Maroon '96 ZX6R.
    There's a yellow 998? nope ... no idea.
    Failing
    Cam
    '03 954
    FuTAnT, May 12, 2004
  7. Chris
    FuTAnT Guest
    BMS Honda
    376 Botany Road
    Beaconsfield
    http://tinyurl.com/3fvza
    They'll sort you out and they are very cheap. They won't rip you off. You'll
    be amazed at how good it will feel after a good service. By all means do it
    yourself, but remember you'll need feeler guages, a torque wrench and a
    micrometer at the very least, plus the rest of the tools etc. Or are the VTR
    screw type adjustment? Big??
    Cam
    '03 954
  8. Chris
    Mike.S Guest
    Since when were you on their payrole Cam? ;-). kidding.
    I agree, they are a good mob, treat you (and your wallet) very well. :)
    Mike.S
    Mike.S, May 13, 2004
  9. Cam wrote: (and yeah, the references header is borked)
    Yep, screw and locknuts on the Spada so you won't need the mic... No
    real need for a torque wrench either, the most important fasteners you
    get to really are the rocker cover bolts... Its not like you're torquing
    up crankshaft nuts or big end bolts...
    big
    Iain Chalmers, May 13, 2004
  10. Chris
    Moike Guest
    So you don't retorque the heads before you set the valve clearances?
    Moike
    Moike, May 13, 2004
  11. So you don't retorque the heads before you set the valve clearances?[/QUOTE]
    Nope, is it customary?
    There's no mention of doing it in either the Spada or the Monster
    service manuals...
    (wondering if he's being trolled or if maybe theres some reason why
    you'd need do this on motors with pushrod driven valve rockers?)
    big
  12. In aus.motorcycles on Thu, 13 May 2004 15:32:26 +1000
    Not for screw and locknut, it is for shim. Which the spada ain't got...
    I suspect Moike is confused.
    Zebee
    Zebee Johnstone, May 13, 2004
  13. Chris
    X-No-archive: yes
    Iain Chalmers wrote in message ...
    Because if you retorque the heads AFTER you set the valve clearances they
    close up!
    Clem
    (this reverse-logic is fun!)
    Knobdoodle, May 13, 2004
  14. Really?
    I'm trying to work out which bits of the valvegear in an overhead cam
    motor (either shim or screw & locknut) would be affected in any way by
    the head bolt torque... Like I said, _maybe_ I can see how a pushrod
    motor might allow the clearances to change when the head gets torqued
    (but even there I'd be quite surprised of theres enough "play" in the
    head <-> headgasket <-> cylinder block <-> crankcase to make any
    difference to the couple of thou tolerance that the valve clearances
    have - can you _really_ compress all of that by a thou or two just by
    tightening the head bolts?)
    And, to further muddy the water, I last checked the valve clearances on
    the Monster while the heads were sitting on the work bench - the head
    bolts were not only not torqued to spec, they weren't even fitted...
    Should I re-check them? (the answer to that is "yes" anyway, since that
    was almost 10,000km ago anyway)
    big
  15. Carry a sawn off shotgun...
    ··»¤·QUOKKA·¤«··, May 13, 2004
  16. Chris
    John Guest
    Yeh biggy, same here. moike, please explain ;)
    If the cam is mounted in the head - would not matter one iota if
    heads tensioned before or after shims done.
    The only thing that comes to mind is if the motor has a gear driven
    cam drive - then i belive if the head is removed - the head gasket has
    to be set up so the clearance for the gear drive is maintained.
    Johno
    John, May 13, 2004
  17. Chris
    GB Guest
    If the head flexes a bit when you tighten it down, then
    it's gonna make a poofteenth of an inch of difference
    somewhere and you'll need to re-do the shims.
    Seemed obvious to me.
    G
    GB, May 13, 2004
  18. Chris
    John Guest
    You could be correct GB, but as i see it - camshaft bolted to head -
    head bolted to barrel - if you tension the head - it alters the
    clearance between the head and barrel (maybe only as you said a
    poofteenth of a inch) but the camshaft will stay the same distance
    from shim bucket.
    Johno
    John, May 13, 2004
  19. Chris
    smack Guest
    I think I"m gonna have to talk to you and the fellow Zeebee's boss about the
    amount of time you spend on this group :)
    smack, May 13, 2004
  20. In aus.motorcycles on Thu, 13 May 2004 19:36:17 +1000
    Well.. when I did the shims on the Kwak, I removed the cams, and I'm
    fairly certain I had to retorque something...
    But it was long ago and far away and the bike is dead.
    Zebee
