bike batteries
Discussion in 'Australian Motorcycles' started by Mad Biker, Sep 16, 2004.
  1. Mad Biker
    Mad Biker Guest
    I got a a toplite bike batterie from super cheep auto yesterday.
    i got home and after some halarity's on irc i relized i needed some acid for
    it as they are empty when stored
    so i went back to see if they would fill it, they wouldnt, but sold me a 1l
    bottle of sulphuric acid for 8 bucks and a filler for 3 bucks.
    I was told to put it in strait, dont dilute it.
    the pipet leaked like a siv and was useless.
    so i used a hydrometer to fill it up slowley. taking half an hour.
    now the battry works..
    do bike batteries normally come unfilled? it seems very odd to me.
    cheers
    Nathan
  2. Mad Biker
    phil Guest
    A friend in the batt biz once showed me some tech info from century
    batterys...it said that a lead acid that is let go to fully flat 3 times has
    half the life of one that isnt. If the batterys were full on the shelf
    waiting to be bought then they would go flat & drastically shorten their
    working life. There are also storage & transport issues with having them
    full. Most bike shops will do it for you once you buy the battery.
    phil, Sep 16, 2004
  3. Yes they are sold empty. Anyone that has been to my old's house may have
    seen the glass and wire container that acid used to be shipped in when the
    family owned the servo in the olden days.
    Shipping batteries with acid is expensive dangerous and detrimental to the
    life of the battery.
    Hammo
    Hamish Alker-Jones, Sep 16, 2004
  4. Mad Biker
    Johnnie5 Guest
    Bike batteries aren't a huge seller so they come dry so that they have a
    long shelf life
    in future buy a small funnel
    or spring for a better battery that has 6 containers of acid , just push
    down and the battery fills itself with the required amount
    make sure that once you have filled it that you wait 8 hours for the acid to
    soak into the plates and then charge it
    Johnnie5, Sep 16, 2004
  5. Mad Biker
    Mad Biker Guest
    i waited 2 hours, the instructions told me 15 minutes recomended but not
    required..
    then gave it a runaround the block for 5 minutes...
    but i have 300mls of acid left, and the old bike battery which still holds
    charge fairly ok..
    what happens if i put new acid in it?
    so what about these maintanance free batteries, that are completely sealed
    that my modern honda's have..
    wont the acid eat the funnel?
    and is 44 bucks + 8 for acid good?
    cheers
    Nathan
  6. Mad Biker
    phil Guest
    Fill the new batt with new acid...put it on a charger overnight or more til
    the specific gravity is up (you have a hydrometer) to about 1.2 or 1.3. END
    STORY
    Hell you can buy a charger for $20 from those shit & glitter shops you got
    the cheap battery from. What makes you think the acid will eat the funnel
    when it wont eat the battery (plastic) or the plastic bottle it is in ? The
    price is relitive...if it last 2 winters then yes.
    phil, Sep 16, 2004
  7. Mad Biker
    Mad Biker Guest
    take a chill pill phil, you sound like bobbys been in your fridge again..
    yes, battery is in its charged, the battery comes dry charged anyway, its
    been on a trickle charge for many hours.. and the hydrometer tells me its
    fully charged..
    why it wont eat the funnel, because its a different plastic type..
  8. Mad Biker
    phil Guest
    Battery acid wont eat plastic in general ... i have 1860g/lt sulphuric acid
    in a plastic bottle in my shed...it fumes when you expose it to air & will
    cut through a folded up rag in literally seconds or skin whilst you look at
    it.
    Picked it up cheap from a snowtown bank auction.
    phil, Sep 16, 2004
  9. Mad Biker
    Conehead Guest
    Better by far to buy a gel battery. When they evenually need replacing, so
    does your bike.
    Conehead, Sep 16, 2004
  10. Mad Biker
    Ron Guest
    Strange.... Must be a "Head" thing...
    Ron, Sep 16, 2004
  11. Mad Biker
    Bobby Guest
    hahahhahahahahahahha phil. looks like a part of me will be in your fridge
    one day :)
    Bobby, Sep 16, 2004
  12. Mad Biker
    Mad Biker Guest
    are the gell ones the maintanance free batteries? the sealed units you cant
    put anything in?
    cheers
  13. Mad Biker
    Mad Biker Guest
    go drink his acid then bubby
  14. Mad Biker
    Johnnie5 Guest
    take old battery and left over acid to the recycling
    you cant put new acid in it
    once you put acid in a battery it is always in there , it is the water that
    evaporates off
    if the battery is stuffed it is stuffed , usualyl through to sulfation of
    the plates
    you fill em , put the cap on and forget about em until your bike wont start
    any more
    not bad
    some interesting reading
    http://www.batterystuff.com/battery/battery_tutorial.htm
    http://www.tpub.com/neets/book1/chapter2/1e.htm
    http://www.uuhome.de/william.darden/
    http://www.yuasabatteries.com/faqs.asp
  15. Mad Biker
    sanbar Guest
    A dose of sulphuric acid in a bowl of sugar is pretty spectacular to
    watch.[1] Your 300ml should do the trick. End result is a very raw form
    of diamonds that you can present as a gift to Mrs Mad Biker.
    - sanbar
    [1] Kids, *don't* do this at home.
    sanbar, Sep 16, 2004
  16. Mad Biker
    glitch1 Guest
    Naw, AFAIK 2 different types.
    The most common today is the sealed lead-acid type as used by most manuf as
    OEM.
    It's "maintenance-free" (non-refillable, no breather hose). It's still a
    fluid-filled item, but sealed.
    Gel's are maintenance free, no breather hose, sealed off, haven't got a clue
    what's inside them (apart from gel replacing the water/acid mix).
    Longer life, higher price, not available for some bikes/ some sizes (unless
    imported individually from UK/US).
    cheers
    pete
    glitch1, Sep 17, 2004
  17. Mad Biker
    Theo Bekkers Guest
    In three years? That's about the life of UPS gel batteries, and they rarely
    get discharged. I used to use gel batteries in a previous Guzzi. They cost
    more but don't last any longer.
    Theo
    Theo Bekkers, Sep 17, 2004
  18. good for trailbikes etc that are likely to go belly-up. Some people also
    get the idea that the sealed maitenance free batteries are gel. Not so, the
    two batteries I put into the VTR were both sealed maintenance free, but you
    still had to put the acid in and put the lid on to seal it before you fitted
    it to the bike. Nice acid bottle/ funnel they had too: 6 small funnels
    moulded in line that you put into the holes for the cells, a small spike
    within each funnel. The acid came in a moulded pack of 6 bottles, each with
    just the right amount of acid, push the bottles down on the spikes and the
    acid runs down the funnels. Too easy.
    Al
    Alan Pennykid, Sep 17, 2004
  19. Mad Biker
    Mad Biker Guest
    should i do that at the breakfast table?
    WWW.MAD-BIKER.COM
    Mad Biker, Sep 17, 2004
  20. Mad Biker
    Johnnie5 Guest
    also gels can be mounted in any position i.e upside down
    they discharge(go flat) a lot slower
    a standard lead acid battery loses on average 1% of charge per day , Gels
    last a lot longer before going flat
    and also usually can charge up quickly and go quite flat before a charge
    without huge damage unlike a lead acid
    battery which if you leave flat for too long then say goodbye to it
    Johnnie5, Sep 17, 2004
