bike speedo's
Discussion in 'Australian Motorcycles' started by Cameron Seeber, Oct 20, 2003.
  1. I have a honda Z50 that I am trying to get registered.
    Honda cant seam to track down a headlight for me, but gave me a CT110 one to
    try out.
    It fits in the bucket no worries, but the back of it is too deep and cuts of
    the area it currently uses for the speedo cable.
    So my question is.
    Can I get a bike speedo or something similar to that and will it still be
    legal?
    I only need it to go to 60-100km/h type range max, as that bike will only
    ever probably go that fast.
    Does anyone know of any aftermarket electronic 2inch or 50mm speedo's?
    The other option is to mount it elsewhere which will probably do for now
    thanks
    Cameron
  2. In aus.motorcycles on Mon, 20 Oct 2003 09:00:06 GMT
    If you are in NSW, then you do not require a speedo to get the bike
    registered. The police may require you to have a way of measuring your
    speed though... a cycle speedo's fine.
    The Sigmas are known to work at speeds faster than a bicycle can go, but
    the cheapies are probably fine for a 50 unless you are planning to try
    and out do CrazyCam and Bluey.
    Zebee
    Zebee Johnstone, Oct 20, 2003
  3. Cameron Seeber
    Dave Ello Guest
    You'd have to have a flouro purple and green flashing scheme with Marchesini
    wheels and carbon cans to outdo Cam. C'mon. :)
    Cheers,
    Dave ZZR600 => ST2 (stolen) => '03 XX
    Dave Ello, Oct 20, 2003
  4. James Mayfield said....
    JM> One issue with pushy speedos though is wet weather. Because they use
    JM> magnets etc to work out how many revolutions the wheel is doing, in the
    JM> wet weather they can get a bit confused. (Something to do with the water
    ROFL.
    Martin Taylor, Oct 23, 2003
