bike trouble
Discussion in 'Australian Motorcycles' started by Neil, Nov 11, 2006.
  1. Neil
    Neil Guest
    hi all got a two stroke which doesnt seem to want to idle, no matter what
    adjustments i make it wont idle and is very sluggish. when i try to get it
    up to top speed it starts to die. any ideas? replace carby? its a auto mixed
    two stroke i took it to a mechanic a while ago and he fixed it but it didnt
    last all that long.
    Neil, Nov 11, 2006
  2. Neil
    J5 Guest
    go through the basics first
    new plug
    carb clean
    check fuel flow is ok
    fit fuel filter if you don't have one
    what bike ?
    J5, Nov 12, 2006
  3. Neil
    Neil Guest
    lots of oil on the plug i think i might need new rings
    Neil, Nov 12, 2006
  4. In aus.motorcycles on Sun, 12 Nov 2006 15:23:08 +1100
    If the bike smokes a lot and you know your timing is right and you
    aren't feeding it too much oil, then you might need rings.
    Oil on the plugs is more likely to be the mixture is too rich.
    Clean your air filter to start with.
    Zebee
    Zebee Johnstone, Nov 12, 2006
  5. Zebee Johnstone, Nov 12, 2006
