Bike vibration
Discussion in 'UK Motorcycles' started by Clive, Apr 8, 2009.
  1. Clive
    Clive Guest
    Hi,
    I have a Suzuki EN125 (grey import) which, after changing the spark
    plug, has been running well.
    However, in the past month I have noticed a subtle change in
    performance. All I can say is the engine sounds a little more strained
    a say 6,000 revs than it did in the past. By “strained” I mean the
    sound is like the screech when I used to rev up to 9,000. Previously
    there was no “screech” at 6,000 revs. Also, the vibration has
    increased. I can feel a buzzing through the handlebar grips, the seat
    and the footpegs that wasn't there before. Finally, I sometimes feel a
    “puffing” sensation on my calves which are about the level of the
    carburettor when I am sitting on the bike. The bike acceleration seems
    OK (it was never stellar) and the fuel consumption seems to still be
    around 90mpg. These changes aren't dramatic but I have noticed them
    and I'm just worried they might be early signs of a big failure
    waiting to happen. Any ideas of things to look at or check?
    Thanks
    Clive
    Clive, Apr 8, 2009
  2. Clive
    TOG@Toil Guest
    Give it a service. Change the oil and filter and check the valve
    clearances. That might be all it is. Those little Suzuki OHC engines
    are pretty tough. Have a squint round the engine with the engine
    running, and the bike on its stand, just in case something is blowing.
    TOG@Toil, Apr 8, 2009
  3. Clive
    Paul - xxx Guest
    I'd check the head/barrel bolts for tightness, and check the
    head/barrel gasket area for signs of oil weeping, the carb to head
    inlet rubber for leaking/tightness, the air filter and rubber inlet to
    carb for leaks/tightness, and the exhaust for same.
    What mileage has it done? They're pretty high-revving engines and need
    to be serviced reasonably and regularly to keep 'em going well. Decent
    oils and filters might help.
    Paul - xxx, Apr 8, 2009
  4. Clive
    Clive Guest
    6,000 mile on 3 year old bike,
    Complete oil and filter change a few weeks ago.
    I used the correct 4-stroke, SL grade oil and a "genuine" Suzuki oil
    filter.
    I will follow the idea of running the engine while the bike is on the
    centre stand and see what I can see.
    Thanks
    Clive
    Clive, Apr 9, 2009
