Bike will not start. Problem getting worse and worse. Help!
Discussion in 'Australian Motorcycles' started by VTR250, Feb 4, 2009.
  1. VTR250
    VTR250 Guest
    Can anyone suggest what's going on here...?
    Bought a Honda VTR 250, 2nd hand in Apr 2006, it was 2 years old, with
    11,000km on the clock. Apr 2006 ,12K service.
    It was reliable all year, except it would not electric start on a
    couple of cold mornings in 2006. I suspected the battery. 16K service
    Jul 2006.
    New battery: Jul 2006 (NB: could this have been a dud?) There was an
    improvement at first, but it still failed to electric start in winter
    2007, on the coldest days. 22K service Feb 2007. 32K service Jun
    2007. 36K service Nov 2007. 42K service Apr 2008.
    Often it failed to start on cold days in winter 2008 (once it needed a
    bump start 5 mornings running). Apr 2008: a Honda dealer went over it
    for a full day and found nothing wrong. They did admit it wouldn't
    start properly. Fitted a new stator: Apr 2008. No significant
    improvement. 48K service Sep 2008.
    Now it needs bump-starting in summer. 3 times in one week (Jan 2009)
    it needed a bump start, and the other 2 times it started normally.
    When it starts right it roars into life after turning over twice.
    When it goes wrong, it's always the same: the engine fails to catch
    and it just turns over and over. Could it be choke/fuel?
    It started OK this morning, so after 30 seconds, I stopped the engine
    and tried again. It needed a bump start.
    Once the engine has warmed up there is usually no problem starting it
    for the rest of the day, even 9 hours later. Only exception was when
    I went for 15 mins and it wouldn't start 3 hours later.
    Any suggestions (apart from trade it in)?
    VTR250, Feb 4, 2009
  2. VTR250
    jl Guest
    Trade it in.
    Try
    - Coil(s)
    - Crack in a solder joint that expands when heated - I'd be looking at
    the starter path first but it could be elsewhere - battery terminals
    etc. A complete bastard to find though
    - Non functioning cold start injector if this motor has one (are they
    carb or efi)
    - malfunctioning temp sensor
    - kill switch
    JL
    jl, Feb 4, 2009
  3. VTR250
    Yeah if it turning and turning but not firing then it's not your battery or
    your stator.
    Has it ever fired (or popped) when it's doing this dead turning or is it a
    total non-event from ignition-switch on through to ignition switch back off
    again? (or kill-switch if that's how you're starting and stopping)
    If that's a "no" the culprit seems pretty obvious.
    If it's sometimes popping and running a few revolutions then it all gets a
    bit harder .....
    Knobdoodle, Feb 4, 2009
  4. VTR250
    VTR250 Guest
    No. Doesn't pop - even if I rev the engine before killing it on the
    previous day. The only noise is the starter motor. What is the pretty
    obvious culprit?
    VTR250, Feb 4, 2009
  5. VTR250
    VTR250 Guest
    Oh, there is ONE thing I should also mention... I took it to a
    different Honda dealer, on one occasion. I explained all the ins and
    outs but the message that got passed to the mechanic was "problem
    starting". The mechanic there messed around with the starter switch
    and broke it. Occasionally the switch can get stuck in and if that
    happens, the headlight goes out. The switch has been stuck in for
    perhaps an hour in total. I don't know whether the starter motor
    would have been turning while the light was off all that time
    (earplugs) but I did experimentally blip the starter switch when the
    engine was running and the starter motor DID turn over. Could I have
    burned out something? I don't think so because the motor winding is
    one long piece of wire isn't it? Either the starter motor would always
    work or it would never work (?)
    VTR250, Feb 4, 2009
  6. VTR250
    obvious culprit?
    OK so is it the kill switch or the ignition switch?
    It's carbs right? If it bump-starts without trouble then forget
    fuel/carbs/tap/choke etc. and stick with electrical.
    When it runs fine and you turn it off but then it won't even pop the next
    time; how did you turn it off/on?
    THAT'S the switch I'd be looking at; cleaning the contacts, jiggling it and
    then trying again, putting a bit of pressure onto it whilst trying it.
    If the starter is spinning strongly every time you push the button then it's
    not that button (whether it sticks in or not).
    You're not in Brisneyland are you?
  7. VTR250
    VTR250 Guest
    Well I'm not sure the bump start is without problems. When it gets
    going it chugs along for several seconds and *then* picks up the
    revs. On cold mornings it can rev a bit and then die away and stop.
    that's why I thought it could be fuel. BTW - if I get to the bottom
    it's hard work getting to the top of the hill.
    As for cutting the engine, generally I use the kill switch, but it
    doesn't seem to make any difference whether I turn off the ignition or
    put the stand down in gear. I used to use the stand and park in gear,
    now I park out of gear and use the kill switch. Makes no difference.
    The problem is slowly getting worse.
    VTR250, Feb 4, 2009
  8. VTR250
    theo Guest
    This would suggest there is no problem with your battery or starter
    motor.
    Sounds electrical to me. When the starter motor is running battery
    voltage drops by at least a volt, maybe two. If you have a weak
    ignition system this will prevent you getting a spark. Cars found a
    solution to this problem many years ago by fitting a resistor in line
    with a 9V coil. When you hit the starter in your car it shorts out the
    resistor whilst the starter motor is turning. This means the 9v coil
    is getting around 10V. Without the resistor a 12V coil getting 10V
    doesn't work very well. I had a Renault 12 once that always had
    problems starting on a cold day and I modified it to a resistor
    ignition.
    Things to check.
    Earth connections. From the battery to the frame, from the frame to
    the engine. Take the coil out and sand the point where it contacts the
    frame, also sand the frame in that spot. The coil mounting bracket on
    bikes is usually mounted in rubber to avoid vibration. Check the earth
    connection back to the frame.
    Good luck.
    Theo
    theo, Feb 4, 2009
  9. VTR250
    knobdoodle Guest
    You or your shop may have already done this and excuse me if I'm
    patronising but:
    To eliminate fuel as the problem get a nice tankfull of premium and
    then turn the bike off and turn the petrol-tap off. (If there's no
    "off" it's a vacuum tap and "on"is fine.)
    No find the drain-screw in the bottom of your carb (generally a no2
    Phillips-head on the side of the lowest part of the rear of the
    carburettor.
    If you don't know what the carb is follow the rubber fuel-line down
    from the fuel-tap. It should be shiny and about 100mm high and
    supported by large-diameter rubber hoses both ends.
    The drain-screw will be real tight so use a correct-fitting
    screwdriver and push it into the head of the screw real hard.
    Watch the fuel as it runs out and look for dirt, rust and bubbles of
    water.
    When the fuel stops dribblein turn your fuel tap to "on" or
    "prime" (vacuum tap) and watch the petrol flow out again.
    when you're satisfied that it's clear and clean screw the screw back
    in to stop the flow. (don't turn the fuel off or the carby will be
    empty and harder to start)
    If you got a decent or half decent flow your tap and fuel-filter(?)
    are OK. If not clean them.
    knobdoodle, Feb 5, 2009
  10. VTR250
    Smeeegles Guest
    I'm with Theo
    I had a similar earthing connection on my old cd250 and it exhibited
    similar problems to yours.
    In my case it turned out to be a loose negative terminal to the battery
    Either way I think there's an earth leak somewhere on your bike.
    check your cluch switch and sidestand switch for filth, rust etc.
    Smeeegles, Feb 5, 2009
  11. Does the starter motor 'click' or does it spin up without spinning the
    motor?
    Peter Cremasco, Feb 9, 2009
  12. FIRST MISTAKE! CRAP BRAND
    TYPICAL HAHAHAHAHAONDA SHIT
    TAKE-STRAIGHT-TO-TIP-OR-SIMS-METAL
    YOU WILL ONLY GET 5 CENTS, WHY BOTHER?
    PaulpULVITZKA, Feb 9, 2009
