Bleeding shock absorber hassles
Discussion in 'UK Motorcycles' started by TOG@Toil, Sep 17, 2010.
  1. TOG@Toil
    crn Guest
    Just a thought - is there another similar-ish bike called a GN250 for
    a different market with different suspension. Or maybe a spec change
    partway through the model life. Such daftness has been known to happen.
    crn, Sep 17, 2010
    #41
  2. No: I tried that.
    The Older Gentleman, Sep 17, 2010
    #42
  3. Not quite that easy as it's a 2-1 system, and spacing out the silencer
    means that not enough header feeds into the collector box.
    #43
  4. No. Because the silencer is on the left, and it fell on the right and
    damaged the r/h shock.
    #44
  5. Not to my knowledge. There are models with a 2-2 exhaust, though.
    #45
  6. Er, other way around. Fell on the left and the pipe is on the right!
    #46
  7. TOG@Toil
    Pete Fisher Guest
    In communiqué <1jozi8c.1uimgo8idd3pcN%>,
    I was thinking more of tweaking it out to the side a bit more. Still
    that's what comes of building too many Morini mix and match frame and
    engine bitzas.
    A mystery, but the shorter dampers that Wemoto are sending will sort it.
    | Pete Fisher at Home: |
    Pete Fisher, Sep 18, 2010
    #47
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pete Fisher
    Whereas, if it were me, I'd 'ave 'it it wivva 'ammer until it fitted.
    Sort of.
    Wicked Uncle Nigel, Sep 18, 2010
    #48
  9. <snip>
    Sorted. One pair of 315mm length shocks and they bolted straight on in
    two minutes. Job done.
    The Older Gentleman, Sep 20, 2010
    #49
