Bloody flat battery
Discussion in 'Australian Motorcycles' started by Will S, Jul 22, 2005.
  1. Will S
    Will S Guest
    Well seeing how I am going around the continent I dont want to risk putting
    something
    back incorrectly an having it stuff up somewhere besides I am lazy
  2. Will S
    Boxer Guest
    I use Odyssey batteries in my BMW's cost about $200.00
    Boxer
    Boxer, Jul 22, 2005
  3. Will S
    Boxer Guest
    About 2 hours work on some BMW's, (my R1100S for example about 2 hours,
    K1100LT about an hour, R100GSPD about 20 minutes)
    Boxer
    Boxer, Jul 22, 2005
  4. Will S
    atec Guest
    I am wondering why the six monthly strip and clean doesn't include a
    battery check .
    atec, Jul 23, 2005
  5. Will S
    atec Guest
    you have to be kidding ?
    To offer some idea I bought a new battery for the Mrs Foulcan under
    $100.00 (500 amph), he said they got $140.00 on weekends fitted but I
    do know the price I got was excellent , I would think $100.00 should
    have been about the retail on a k100 battery ? considering the material
    cost .( it was locally made )
    atec, Jul 23, 2005
  6. Will S
    Moike Guest
    heh, must be a BMW thing.
    On the R100RS, some recommended procedures include removing the air
    filter, others suggest unbolting and moving the rear mudguard, and I've
    seen one suggestion that the best way is to remove the top mounting
    bolts that hold the rear subframe and lower the subframe. In most cases
    you seem to need to remove or loosen almost inacessible mounting bolts
    on the battery carrier. I find that if I remove the nuts on the
    subframe bolts and slide the bolts halfway out the gap is only about 1.5
    mm smaller than the battery, so I can usually force the battery out
    without doing too much damage to it.
    I hate changing over the battery.
    Moike
    Moike, Jul 23, 2005
  7. Will S
    Howie Guest
    I was quoted $162 for a Yuasa and $100 for a Toplite for a Suzi GSX-R 750
    from Battery World in Redcliffe. Getting a SuperCharge battery for $50
    instead.
    Howard Collins An e-mail from Howard to you.....
    Howie, Jul 23, 2005
  8. Will S
    Mad-Biker Guest
    Just remember, bike batteries come empty, you have to buy acid for them
    extra!
    stupid Cheep auto sucked me into that, and their battery filler pipette
    doesn't work either.
    Mad-Biker, Jul 23, 2005
  9. Will S
    atec Guest
    Small funnel ( say the one from your beer kit) and 5 minutes..
    atec, Jul 23, 2005
  10. In aus.motorcycles on Sat, 23 Jul 2005 15:23:34 +1000
    <snip 7 lines or so of unbolting and unplugging and sliding and
    fiddling...>
    Hmm..
    on 3 bikes it is : lift up seat. Unbolt terminals. Remove battery.
    (The scooter requires "unlock seat" first.)
    On the others it's
    - undo battery strap, remove battery. (although on the Devil, "loosen
    horn and move it a bit sideways" is advisable.
    or
    - unscrew sidecovers via single thumbscrew each side. Unbolt terminals.
    Remove battery
    Although it doesn't make up for 16 bloody bolts to get to the oil
    filter.
    Zebee
    Zebee Johnstone, Jul 23, 2005
  11. Will S
    Will S Guest
    2003 model
    about 30 months old
    Get a new one in a week ir so ( battery )
    Will S, Jul 23, 2005
  12. Will S
    DaZZa Guest
    Best I could find when recently looking for a K100 battery was something
    like $137.
    I ended up paying around $160 {including the acid} for the genuine BMW
    one because the local shop had one in stock, instead of needing to order
    one in.
    DaZZa
    DaZZa, Jul 24, 2005
  13. Will S
    Will S Guest
    $160 is what they quoted me
    Will S, Jul 24, 2005
  14. Will S
    Cameron Guest
    I've got a 2002 ZX9. I've had it for 2 &1/2 yrs. Still got the original YUSA
    battery in it and still running strong.
    Cameron, Jul 24, 2005
  15. Will S
    John Littler Guest
    Hmm 3 of the last 4 bikes were the same - lift seat undo terminals,
    remove battery. TRX, Bandit and Raptor. No idea for the R1 - didn't have
    it long enough.
    JL
    John Littler, Jul 24, 2005
  16. Will S
    Graham Guest
    My GSXF has still got the original battery , its a 1998 model.
    Graham
    GSX750F
    Graham, Jul 24, 2005
  17. Will S
    Red ZZR11 Guest
    It varies a great deal. I have found that if you make a habit of parking the
    bike using the centrestand instead of the sidestand, you can almost double
    the life of your battery.
    Has to do with acid levels and exposing the plates. Don't laugh, this does
    work.
    Red ZZR11, Jul 24, 2005
  18. Will S
    Rusty Guest
    Two of mine are pretty simple:
    The first:
    Lift seat (two convenient levers), remove side cover (pulls off, no
    screws), grab 10mm socket and undo terminals and battery clamp. Large
    Phillips head screwdriver will suffice, but one likes the low effort
    kind of tools better.
    The second:
    Lift seat (requires key). With the trusty 10mm socket from the previous
    job, remove battery cover (4 bolts). Remove terminals and remove battery.
    The third's even simpler. What battery?
    Rusty, Jul 24, 2005
  19. Will S
    Rusty Guest
    Interesting you say that. My ZZR has the original battery in it (1995)
    which still works ok, but I don't think it'll last too much longer.
    It gets ridden every day and is usually parked on the centrestand.
    Rusty, Jul 24, 2005
  20. Will S
    ck Guest
    R1 is the same - undo rider seat (2 bolts) and there it is
    ck
    ck, Jul 25, 2005
