Bloody how much?!
Discussion in 'UK Motorcycles' started by Catman, Jan 26, 2008.
  1. Catman
    Ben Guest
    Yeah, don't lose it!
    I think mine is because not only does it have ecu-matched security
    gubbins in it, it is also the remote plipper. Annoyingly, they don't
    give you a spare plipper, only a normal key.
    The ZX10 has expensive ones as well, but at least that comes with 3
    normal keys, plus a master.
    Ben, Jan 26, 2008
  2. Catman
    Speedgazebo Guest
    I've always found Keys Galore in Primrose Hill (London) to have
    almost any key for anything. Got a key off the shelf for my 1972 ST 70
    for a tenner.
    Mind you, the second one I got cut at Timpson's was only £6.
    http://www.allinlondon.co.uk/directory/1259/13609.php
    Speedgazebo, Jan 26, 2008
  3. Catman
    Catman Guest
    Well the 166 was £160, but it was electronic.
    www.cuore-sportivo.co.uk
  4. Catman
    Catman Guest
    Still needs cutting as well.....
  5. Catman
    Catman Guest
    Interesting, ta.
  6. Catman
    Greybeard says...
    Contact any Givi agent and they'll supply a matching lockset to fit one,
    two or three boxes. They're not expensive.
    Lozzo, Jan 26, 2008
  7. £175 or the relay / boxer / ducati key plus £45.00 to programme it
    steve robinson, Jan 26, 2008
  8. Catman
    Catman Guest
    *ouch*
    Catman, Jan 27, 2008
  9. Catman
    Adrian Guest
    That's a big ol' van to be dragged along by a v-twin.
    Adrian, Jan 27, 2008
  10. Catman
    Greybeard Guest
    That's what I thought I'd done, with our friend at Ongar M/c's, but I ended
    up wiv a bloo one, instead of a red one (I don't know whether the colour
    actually makes any difference TBH) but it doesn't fit.
    I haven't tried since, but it was on about 8 quid IIRC, so I'm not over
    bothered.
    Next time I'm that way, or near a Givi dealer I'll order another one. I feel
    though, if I order another one from Ongar, I'll end up with a matching pair
    that don't fit ;o)
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy2!)
    Trumpet Trophy 1200-03
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Jan 27, 2008
  11. Catman
    Greybeard says...
    I'm not on about keys, I'm on about complete locks with keys. Swopping
    the whole lock is simple. Givi locks are standardised throughout their
    whole range, they fit any box they make and have done for years.
    Lozzo, Jan 27, 2008
  12. Those old Rickman top boxes always used to have the same lock, all of
    'em. A new lockset cost a few quid. I've actually got one or two in the
    garage, c/w keys.
    The Older Gentleman, Jan 27, 2008
  13. Catman
    Beav Guest
    Well as it happened, this bloke is relatively unpikey, but was having his
    Landrover fettled at our place so I just took the opportunity. I still had
    an original key, but only one and a spare key is always handy and the
    lockman has never failed us before. We use him quite a lot coz being
    involved with cars and bikes on a daily basis (some owned by wimmin) means
    we have more than our fair share of "I've broken/lost/bent/locked my key
    inside the car" episodes than most and he's always managed to get a door
    open, remove a broken bit of key, or cut a new one that fits.
    It seems that it's only bikes that cause the problem too, or maybe it's just
    when the fucking key is for me.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 27, 2008
  14. Catman
    Beav Guest
    It's either 8 or 9 of them hundreds too, IIRC.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 27, 2008
  15. Catman
    Beav Guest
    The Z1000 only comes with two keys and I managed to lose on in Germany.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 27, 2008
  16. Catman
    Beav Guest
    I asked Fiat for one to replace one for a Fiat Cinquicento. Over 800 quid.
    Then I found the original under the seat and no, it wasn't my car.
    Fortunately, I found it BEFORE I bought the replacement.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 27, 2008
  17. Catman
    More than it was actually worth then a week after it left the showroom.
    Hog, Jan 27, 2008
  18. Certainly more than the car was worth. He flogged it for £100, and if
    the bloke who bought it knew a way of getting in running again on the
    cheap, good luck to him. Was his attitude.
  19. Catman
    Greybeard Guest
    Sorry, I obviously didn't make myself clear.
    This was for a whole lock and 2 key set.
    These don't fit, as I think they might be Kappa ones? as when you put the
    key in the "idle " position, for a better word, the whole lock assembly sits
    at 45 degrees to the hole. It can't be lined up! Both Rob and myself were
    rather surprised by this.
    Greybeard
  20. Catman
    Beav Guest
    More than it was worth when it was IN the showroom too.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 27, 2008
