Bloody two strokes!
Discussion in 'UK Motorcycles' started by WavyDavy, Apr 4, 2005.
  1. WavyDavy
    WavyDavy Guest
    Or, more correctly, Bloody Terry Shepherd NS400 to 500cc conversions...
    Just had a call from the shop about, oh I don't know, the 20th problem
    they've had....
    The latest one for TS's "bolt-on" kit is that, now the engine is all
    together, and now that the pistons have bee machined to fit, and now that
    the exhausts finally fit properly..... The extra height and width of the
    cylinders has pushed the carbs up too high so they foul on the frame. Only
    available solution appears to be hacking lumps from the frame to fit the
    carbs in... How the aibox and tank will then fit is, of course, not known
    yet....
    So the prospect of the NS appearing in time for Saturday is looking bleak to
    say the least.. :(
  2. WavyDavy
    Robbo Guest
    attach flexipipe style hose to the intakes and mount the box somewhere else.
    Failing that fit Bellmouths ;-)
    Robbo
    Trophy 1200 1998
    B.O.S.M 2003, 2004
    FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Apr 4, 2005
  3. WavyDavy
    Spete Guest
    Anything to avoid the CIHAGM fest eh?
    Spete, Apr 4, 2005
  4. WavyDavy
    Sounds like they've not done it very many times before.
    I'm sure that there is a better solution than hacking lumps out of the
    frame. Can the engine be moved slightly on its mounts, or the inlet
    manifolds be modified?
    So you'll be in the car then.
    Muck, Apr 4, 2005
  5. WavyDavy
    WavyDavy Guest
    First and last they'll ever do by all accounts... Just glad I didn't try to
    do it myself...
    Engine can't be moved due to clearance needed for spannies etc.... I think
    its partly my fault for having a race-tune rather than road. I'm going to
    have a look tomorrow i I get time, but from what I was told, taking a small
    bit of frame out is the only way. I'm hoping that we're only talking little
    bits of frame, though...
    Well Kate has offered up her R6. But I can't see the point in bring a bike
    other than the NS, so Alfa it is[1], stuffed with tents and airbeds and
    whatever else I can fit in.. :(
    [1] Unless it's very very nice and hot and sunny when the R6 will be quite
    good fun on the roads near the BH...
  6. WavyDavy
    Bear says...
    But they wrote it off in short order.
    Lozzo, Apr 4, 2005
  7. WavyDavy
    Bear says...
    Lozzo, Apr 4, 2005
  8. WavyDavy
    Salad Dodger Guest
    Wanna buy a *proper* two-stroke triple? :)
    Much reliability.
    | ___ Salad Dodger
    |_\_____/_| ..73850../..18203.../..3184./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 5 Pts: 90 Miles: 455
    Salad Dodger, Apr 4, 2005
  9. WavyDavy
    More than 3000 miles without taking it apart? Wow... ;)
    Muck, Apr 4, 2005
  10. WavyDavy
    Salad Dodger Guest
    I shouldn't think so. This one's only just done 3000 miles, and it's
    on its second engine.
    | ___ Salad Dodger
  11. WavyDavy
    No wonder you take the wing to events like *OSM.
    Muck, Apr 4, 2005
  12. Or even just to the shop at the end of the road.
    The Older Gentleman, Apr 5, 2005
