Bloody weather
Discussion in 'UK Motorcycles' started by SteveH, Feb 4, 2007.
  1. SteveH
    deadmail Guest
    I'm happy*ish* with the Oxford bar muffs I've got but they seem to die
    after about two years of over winter use which seems a little on the
    light side really.
    deadmail, Feb 4, 2007
  2. SteveH
    says...
    I should have worded that better, I meant Oxford heated grips, not all
    Oxford Products ranges. On top of my wardrobe is a full set of Oxford
    Products Sports luggage that I've had for a few years now, and I cannot
    fault it. It's been overloaded, abused and generally treated like shit,
    but it still looks like new and does everything expected of it.
    Lozzo, Feb 4, 2007
  3. How to undo the exercise benefit from your running down dark lanes in
    one easy step.
    Even I (as a fat lump) refuse to start buying those things - I know I'd
    be on a losing streak if I started. I have had a couple of them when
    people have brought them into the office as celebratory eats and I find
    them almost too sweet.
    Paul Corfield, Feb 4, 2007
  4. SteveH
    deadmail Guest
    Ah, but the exercise isn't for weight control purposes it's training for
    a half marathon.
    They're fantastic.
    I'm craving carbs and sugars furiously at the moment. Probably because
    I'm burning more than 4000 calories a week with my running. >1000
    calories this morning on the weekly 'long run' which was 8 miles, done
    in 1 hour 5 minutes. The same route took me 1 hour 11 minutes four
    weeks ago so I'm getting faster but maybe not fast enough, I need to get
    this down to about an hour to achieve my target time.
    I think that faster than 1:39 for the half marathon is going to be
    *hard* work to achieve but I've not *yet* ruled it out. It all depends
    on my not injuring myself and at the moment my calves feel right on the
    edge and *could* cause problems... roll on the ibuprofen!
    I'll be happy if I complete in 1:50 (he lied)
  5. SteveH
    ginge Guest
    Ditto, but rather than my previous routes via Watford or Elstree &
    Borehamwood, I think I'll be using darsy's recommendation of Cockfosters
    in future, 'cause the parking is better.
    ginge, Feb 4, 2007
  6. SteveH
    deadmail Guest
    well I used to use the car park at Osterleigh since it was convenient
    but the downside was it's a fucking long way out on the tube. HEX is
    best by a longway, if a little expensive.
  7. And you get a better class of driver?
    Steve Fitzgerald, Feb 4, 2007
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Yep, they were OK. The first set packed up, but were replaced under
    warranty. Funnily enough, I found the missing one this weekend.
    Oi! DnC! D'you want it? It's part of the ZZR11 deal, so it's yours.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Wicked Uncle Nigel, Feb 4, 2007
  9. SteveH
    SD Guest
    They make the grips very fat. I've got hands like dinner plates, and
    found them awkward to use.
    What is it, a AA cell or summat? Total loss system?
    | ___ Salad Dodger
    |_\_____/_| ..87918../..23274.../..31893.
    SD, Feb 4, 2007
  10. SteveH
    SteveH Guest
    Hmmm, thing is, I don't want the hassle of a permanent solution, given
    that I rarely go out on it when the temp. is under 10 degrees.
    It all adds up - sat. nav., iPod, heated grips, 2 x whatever watts
    headlamp bulbs etc.
    The battery in it looks a bit pathetic, really.
    SteveH, Feb 4, 2007
  11. SteveH
    SteveH says...
    The proper heated grips just take as much fitting as the wrap around
    type. You've got the same amount of connections to be made into the
    wiring loom and the same amount of cables running up to the bars and
    switch. All that's different is you need to swop the grips themselves
    over, which takes 10 minutes.
    Proper heated grips look like they're meant to be there and don't feel
    too fat when you're riding.
    Lozzo, Feb 4, 2007
  12. SteveH
    SD Guest
    Maybe, but shawly it'll be drawing power off the alternator?
    A quick google suggests it puts out 470W. Plenty.
    | ___ Salad Dodger
    SD, Feb 4, 2007
  13. SteveH
    SteveH Guest
    Loom!?
    I was just going to stick 'em on an inline fuse connected straight to
    the battery.....
    SteveH, Feb 4, 2007
  14. SteveH
    (SteveH) wrote in
    Battery size is irrelevant except for starting. Alternator output is the
    key to being able to run lots of accessories and restore the battery to
    start the bike next time.
    Oh, and you need to take it over 3000 rpm to get the alternator working
    properly....
    wessie, Feb 4, 2007
  15. SteveH
    SteveH Guest
    I'm fucked, then ;-)
    SteveH, Feb 4, 2007
  16. SteveH
    SteveH says...
    Great, until you forget to switch them off and the battery is fucked
    next time you go to start it, or some fucking kid switches them on while
    you're away from the bike.
    Lozzo, Feb 4, 2007
  17. SteveH
    deadmail Guest
    I think the horn provides a convenient +12v switched supply in many
    cases; or at least it's one I've used. Like you I'd not use an
    unswitched supply since I'd forget about switching them off.
    Unlike you I'd rely on the superior Teutonic heaters fitted to my BMW.
    'course that would be more likely to be the climate control variety than
    poxy heated grips...
  18. SteveH
    says...
    I think you mean negative switched, much the same as interior lights on
    most cars. Power permanently at the bulb, which is switched by
    completing the earth side of the circuit.
    I tried to connect into the horn circuit on the Bindits, but my old
    model and Tori's new model are both switched in the positive, meaning
    there's no power at all until the button is pushed.
    Lozzo, Feb 4, 2007
  19. SteveH
    deadmail Guest
    I meant there was a convenient +12v switched by the ignition rather than
    commenting on how the horn was actuated.
  20. SteveH
    says...
    Ah right, I thought you were refering to the way most horns used to be
    switched, in the negative - my mistake.
    The Daytonas come with full instructions as to which cable to tap into
    on the 4 Japanese maker's machines, on the Bindit it's the orange cable
    and on Steve's Honda it'll be the black wires.
    Lozzo, Feb 4, 2007
