BMW ABS Light
Discussion in 'Australian Motorcycles' started by Pisshead Pete, Oct 12, 2004.
  1. Big horse GS thing. ABS light is annoying. Anyone know how to fix it
    (stupid question)? Brakes seem to work fine tho' may have a bit of a
    surge. Please let Clem know at the dinner.
  2. Pisshead Pete
    Boxer Guest
    To disable ABS
    When riding offroad on certain surfaces some riders prefer to disable ABS.
    To do so:
    1.. Turn ignition off.
    2.. Press and hold the ABS reset button.
    3.. Turn ignition on.
    4.. Release the ABS reset button.
    5.. Start the engine and ride off.
    6.. If the ABS lights continue flashing, ABS is disabled until the next
    time you switch on normally.
    The brakes work normally so now it is possible to lock your wheels.
    If no lights are on (and you hear that grating clunk as you move off) then
    ABS is still engaged - stop and try again.
    7.. Press the ABS reset button to stop the annoying flashing and leave one
    red light permanently on. (You have to repeat this at intervals).
    ABS Reset
    Another situation that owners should possibly either know how to deal with
    or else carry a set of printed instructions for, is ABS reset.
    In certain situations e.g. after an off, the ABS needs to be reset. You can
    see this because the red ABS warning lights flash not together as they
    normally do but alternately. The brakes are unaffected.
    Normally a dealer has to reset the ABS. However several owners said that the
    last thing they wanted after coming off was to have non-functioning ABS. The
    following procedure can also be used. It is useful to carry a short length
    of wire stripped at both ends.
    2.. Remove pillion and rider seats.
    3.. Locate the 3 wire plug by the toolkit and remove the blue termination.
    (It's for diagnostics so is not connected to anything).
    4.. Insert one end of wire into the *middle* socket.
    5.. Clip the other end firmly to ground.
    6.. Turn ignition on. Note that the two ABS lights continue flashing
    alternately.
    7.. Hold ABS button down for 8 seconds. The bottom ABS light should stay
    on, the top one off.
    8.. Release the ABS button.
    a.. If the reset is successful, both ABS lights come on.
    b.. If you didn't count to 8 or your ground is not good, then the top
    ABS light stays off. Start again and/or try pressing the ABS button before
    turning ignition on.
    9.. Turn ignition off, remove wire, reconnect plug and refit blue
    termination.
    Boxer, Oct 12, 2004
  3. Thanks John. Unfortunately he's just left before the 'puter was turned on.
    Can someone print this out for him?
    Pisshead Pete, Oct 13, 2004
  4. Pisshead Pete
    Conehead Guest
    ABS light is the first indication that the battery is not getting fully
    charged or isn't holding a charge, so any other remedies won't work
    consistently unless the battery is in good nick.
    Conehead, Oct 13, 2004
  5. Thanks CH, passed on. How's those staples holding up?
  6. Not going to PI now Pete?
    Postman Pat (as featured in today's Telegraph)
    Pat Heslewood, Oct 13, 2004
  7. Yes.
  8. Pisshead Pete
    Nev.. Guest
    He was still asking about this last night so I'll take a copy to the island
    for him when I leave... any minute now.
    Nev..
    Nev.., Oct 15, 2004
  9. Pisshead Pete
    This worked a treat thank you very much John.
    I had Moike holding a lump of fence-wire earthing out the lead while I
    was pushing buttons and counting and I'm now awash in ABSie-goodness.
    (There was even a convenient dirt-road at Surf-Beach for the
    test-ride!)
    Thanks again,
    Clem
    Knobdoodle, Oct 17, 2004
  10. Pisshead Pete
    Yep I did have that problem before I replaced the battery thanks
    Coney, but this was a different, more persistent thing.
    Clem
  11. Pisshead Pete
    How're you doing these days, old timer? It sounded like you were
    going to be leaving a whole lot behind at the hospital...
    BT Humble, Oct 18, 2004
  12. Pisshead Pete
    Boxer Guest
    Very happy to pass on the "Good Oil" this and many other incantations are
    held in trust by those of the BMW Club.
    Boxer
    Boxer, Oct 18, 2004
  13. Pisshead Pete
    Conehead Guest
    Gday BT
    Left half my large bowel at the hospital on the 29th Sept. It takes ages to
    get that hospital smell out of ones system.
    Will have radiation & chemo in a month or so to quieten the remaining
    primary cancer in the body wall, then they'll use chemo on the secondaries
    in liver & lymph nodes if symptoms arise.
    My stomach looks more unattractive than usual thanks to infection in the
    wound, but it didn't stop me having my first ride today since the operation.
    Should have topped up the painkillers first, though. I didn't realise there
    were so many sharp bumps in the roads.
    It was beaut to be on the bike again, and I didn't even stop singing when a
    bee stung me on the chin. [1]
    Conehead, Oct 18, 2004
  14. Glad to see you're up and about again Coney.
    Pity you don't still have the GS--the pus would've matched the paintwork.
    Postman Pat
    Pat Heslewood, Oct 18, 2004
  15. Pisshead Pete
    I'm hoping to be headed down your way for a week or so around
    February. Perhaps we could go for a ride, once I've finished standing
    awestruck in the middle of Smack's palace-like shed.[1]
    [1] Here's my #2 shed: http://evilurl.com/smuttywadfacial
  16. Pisshead Pete
    smack Guest
    Never thought I'd see a forum about shed building.
    You wanna book the palace for Feb?
    smack, Oct 19, 2004
  17. Pisshead Pete
    Conehead Guest
    A ride would be great....and it will be about time for an Ausmoto National
    Dinner.
    As for the shed, smack's bar in the corner of his shed is bigger than your
    whole #2 building!
    Conehead, Oct 19, 2004
  18. Pisshead Pete
    Wow: you must've been hours on evilurl to get such an appropriate shortcut!
    Clem
    Knobdoodle, Oct 19, 2004
  19. Pisshead Pete
    And I was just thinking on the ride in this morning how long it had
    been since somebody had made a booth joke...
    BT Humble, Oct 19, 2004
  20. Pisshead Pete
    It's not wot yer've got mate, it how yer use it! ;-)
