bmw doing something wrong...
Discussion in 'UK Motorcycles' started by Owen, Sep 13, 2010.
  1. Owen
    Owen Guest
    Is there anyone locally that can come and ride my bmw 1150 and tell me
    whats wrong?
    Ive got a little bit of slap and would loke to know the cause...
    Im in reading...
    (long-shot, I know...)
    Owen, Sep 13, 2010
  2. Owen
    Check tyre pressures before anything else & check the tyres. There was a
    dodgy batch of Tourances around a while ago. Fronts with weird wear
    patterns and delamination in a few extreme cases.
    If the tyres are okay then define slap? Steering, rear end wiggling?
    I'm in S.Wales so any diagnostics will be done remotely.
    This bloke is not far from you, in SW15
    http://www.gsshop.biz/
    He has a very good reputation and is cheap.
    wessie, Sep 13, 2010
  3. Owen
    Owen has an R1150GS. I thought it was the R1200GS that had the chocolate FD
    bearing? On the R1150 there is an adjuster on the paralever bearing. I've
    had mine tweaked twice in the 48,000 miles the bike has covered. If the
    bearing has failed then I beleieve it is a relatively cheap & simple fix on
    the R1150.
    According to UKGSer there have been loads of R1200 FD failures and BMW were
    not supplying the parts for the units to be fixed. Dealers were being
    encouraged to replace the whole FD. I think bearing kits are now available
    as I don't think BMW could keep up with demand for the complete FD
    assemblies. Some people are on to their second or third replacement and
    just keep extending their factory warranty in anticipation of a future
    claim.
  4. Owen
    Owen Guest
    Tyre pressures are fine, Ive got a clutch or drive related problem.
    Theres a thwack when I let the clutch out, its slowly getting worse...
    Owen, Sep 13, 2010
  5. Owen
    take it to Neil at the GSShop - he'll probably diagnose the problem pretty
    quickly and if there is something wrong, fix it cheaper than most. He's
    usually got a courtesy bike kicking about.
