BMW K series battery
Discussion in 'UK Motorcycles' started by Andy Bonwick, Nov 22, 2009.
  1. Andy Bonwick
    So which one do I go for?
    The old Varta one is completely fucked so do I replace it with similar
    or go for a slightly dearer gel one?
    Bear in mind I might well be taking this bike to the arctic circle
    this winter so would the gel be a better bet in those conditions?
  2. Andy Bonwick
    Depends on which Gel battery you're looking at, but my guess would be
    something like an Odyssey gel should be what you want.
    Timo Geusch, Nov 22, 2009
  3. Andy Bonwick
    Steve Parry Guest
    Without any hesitation I'd recommend the Odyssey battery from Motorworks,
    don't forget the battery post adaptors.I have one in my BoxerCup and it's
    not failed to turn over the big lump :)
    They also do as an option the genuine BMW gel battery which is considerably
    cheaper than the Odyssey. As this is the type fitted to my K12GT I can only
    say it's not given any issues either.
    Steve Parry
    BMW R80RS, 03 BMW R1100S Boxercup, 07 K1200GT SE
    02 Suzuki DRZ400S, 87 Yamaha FS1, Sukida SK90PY, 91 Kawasaki AR50,
    www.gwynfryn.co.uk
    Steve Parry, Nov 22, 2009
  4. Andy Bonwick
    Well that's two votes from people who ride the beasts so that's fairly
    convincing.
    The one that stands out when I look at them is that the Varta battery
    is 30ah whereas the Odyssey is 19ah. I'll be putting all sorts of
    drains on the battery so should I worry about this?
  5. Andy Bonwick
    Steve Parry Guest
    I seem to recall it's an apple and pears measurement comparing the std 30ah
    to the agm 19ah, an electro chemist maybe along shortly to explain :)
    Steve Parry
    www.gwynfryn.co.uk
  6. Andy Bonwick
    You should be more worried about the alternator's capacity to replace the
    energy consumed. If this is not the case then all the 30Ah battery will do
    is delay the inevitable.
    wessie, Nov 22, 2009
  7. Andy Bonwick
    Pete Fisher Guest
    I went for a Varta on the tart, but that suffers from the opposite
    problem - boiling the battery as a result of the location. In any case,
    I had to get it at very short notice (the same day) and couldn't find an
    Odyssey locally.
    The Westco on the MX5 is OK. It resuscitated OK on an original Optimate
    (took 5 days though) after going flat when left for 6 weeks unused
    without disconnecting it (old style Clifford alarm to blame).
    | Pete Fisher at Home: |
    Pete Fisher, Nov 22, 2009
  8. Andy Bonwick
    I've looked a bit more and it does appear that the Odyssey PC925L is
    the way to go.
    It's getting on for being double the price which is a bit of a blow
    when you consider the outfit hardly gets used but an extra £60 would
    seem **** all if it let me down in freezing conditions.
    I'll probably leave it until I'm sure I'll take the outfit because I
    can run the bike up on a smaller battery and take it for an MOT with
    any old battery wedged in with bits of wood :)
  9. Andy Bonwick
    On Sun, 22 Nov 2009 16:36:24 +0000 (UTC), wessie
    snip>
    **** off you pessimistic ****.
    I'll get around to checking the output one day...
  10. I'd recommend anything from MW, actually. Class operation.
    The Older Gentleman, Nov 22, 2009
  11. Andy Bonwick
    Nige Guest
    Is that the place in Holmfirth?
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Nov 22, 2009
  12. Andy Bonwick
    ts Guest
    THe one they list for the K100 is a 19 AH one. If you feel tempted to go
    for the Westco 30 AH one (53030), be aware that it may be just too tall
    for the battery retaining bolts to reach their threads (unlike my
    previous 53030 of the "Banner" brand. This is the reason why my R now
    has a Westco 30 AH fitted . . .
    ts, Nov 22, 2009
  13. Andy Bonwick
    ts Guest
    Well you know some arctic "explorers" fit higher output alternators to
    their bikes, e.g in the 7-800 W range?
    ts, Nov 22, 2009
  14. Andy Bonwick
    'Hog Guest
    While the Odyssey is probably the one to go for remember the bloke at MW has
    done all the winter rallies and Finland. He will put you in the right
    direction I'm sure.
    'Hog, Nov 22, 2009
  15. No idea. Just Google for MotorWorks.
  16. Andy Bonwick
    Nige Guest
    Aye, thats the place, not too far from here.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Nov 22, 2009
  17. Andy Bonwick
    Nige Guest
    Thanks ****, what a pile of steaming shit out cabbage that was.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Nov 22, 2009
  18. Andy Bonwick
    Nige Guest
    Upperthong?
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Nov 22, 2009
  19. Andy Bonwick
    From the Dictionary of Eye-Watering Words:
    "Upperthong: n. A minimal bra composed chiefly of string, worn by
    certain ladies of negotiable virtue"
    Pip Luscher, Nov 22, 2009
  20. Andy Bonwick
    Nige Guest
    It's a place Pip, very near Holmfirth :)
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Nov 22, 2009
