having problem with petrol pump not starting when engine turned on,tested pump straight to battery working ok,hoping thats the way u test it ,checked fuses, relays,bike turning fine no petrol,reaching sparks,before i buy new pump does it seem its a wiring problem,or the pump,clocks fine,battery fine ,earth cleaned checked,just happened after a bout of backfiring the night before ,then pump wouldnt kick in,is there anything else i should look for,not sidestand switch was already disconnected,before i start to go in to the wiring loom,any help would be grateful thanks kevin BMW K100RS 16V 1991
