BMW R1100 RT
Discussion in 'UK Motorcycles' started by Jeremy, Nov 14, 2006.
  1. Jeremy
    wessie says...
    http://www.epinions.com/content_4146897028
    http://www.epinions.com/content_3358498948
    Lozzo
    GSF600SW (broked)
    'I do not object to people looking at their watches when I am speaking.
    But I strongly object when they start shaking them to make certain they
    are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
    Lozzo, Nov 14, 2006
  2. Jeremy
    wessie, Nov 14, 2006
  3. Jeremy
    wessie says...
    Do they make them any different for the US market?
    Lozzo
    GSF600SW (broked)
    Lozzo, Nov 14, 2006
  4. Jeremy
    As nobody else has made the effort: "New boxers are pants."
    platypus, Nov 14, 2006
  5. Jeremy
    Yes
  6. Jeremy
    wessie says...
    So you're telling me that they have different quality of parts and
    assembly specifically for the US market.
    Lozzo
    GSF600SW (broked)
    Lozzo, Nov 14, 2006
  7. Jeremy
    Read your question again. I answered it correctly. Without checking any
    parts lists I'm certain that at least the headlamp deflectors are
    different.
  8. Jeremy
    deadmail Guest
    TOG@toil, ,
    You don't want an 1100 or any of the 4v per cylinder K series. They
    aren't anywhere near as robust as the 2v per cylinder varients.
    deadmail, Nov 14, 2006
  9. Jeremy
    @news.individual.net:
    :p :p
  10. In uk.rec.motorcycles, Lozzo belched forth and ejected the following:
    Hahahaha!
    Whinging Courier, Nov 15, 2006
  11. Jeremy
    Jeremy Guest
    Well it's very much a "tourer" in a way that the Sprint isn't and it's
    possible then that the RT would stay, the Sprint might be replaced by
    something else. Anyway this is largely thinking aloud.
    Thanks to all for the comments on RTs though.
    Jeremy, Nov 15, 2006
  12. Jeremy
    Jeremy Guest
    What's a good choice from the 2v range in your opinion?
  13. Jeremy
    Charlie Guest
    I believe so. He joined the Crocketts at SPC, buying a majority stake, then
    bought Steve's remaining minority interest 2-3 years ago. There was a major
    refurb, whic turned it into a really good shop. Excellent display and 'toys
    and kit' area, a comfortable internet-enabled caff/waiting-area and a rather
    good workshop behind. I wonder if anyone would have the bottle to take it
    on as a project, as the roads around there are ideal for 'test rides'.
    Charlie, Nov 15, 2006
  14. Jeremy
    You want something late in the 2V range. 1986 on say. Don't be scared by
    the ABS1 system, it's clunky and heavy but it works well and is
    reliable. K100RS or RT/LT or a K75S. Avoid the naked versions.
    I think the later 4V are ok, once they had reliability in the Bosch
    M-tronic DME sorted. A late K1100RS or RT/LT is an ok bike.
    I personally do not like the 4V 1000cc bikes, the K100RS. I found them
    buzzy and required more revving. They do have better brakes and tyre
    sizes.
    Hog, Nov 15, 2006
  15. Jeremy
    deadmail Guest
    I'll take your word on the K1100; everything I've read describes them as
    (relatively) fragile; i.e. good for 80k and then it can get expensive.
    Regarding the 2v engines, I'd go for a late(ish) K100RT/LT or, if you
    don't need to be able to cruise at 110 a lateish K75RT which I think is
    a nicer bike; it's a little lighter but, more importantly the engine is
    a lot smoother.
    I'm not really a fan of the ABS on the 1100 and wouldn't be bothered
    about it on another; if it goes wrong it's coming off...
    deadmail, Nov 15, 2006
  16. Jeremy
    Nick says...
    That all depends on what bikes it was up against. Road tests also very
    rarely take into account long term ownership and the problems
    encountered therein.
    Lozzo
    GSF600SW (broked)
    Lozzo, Nov 15, 2006
  17. Jeremy
    Yes. It's pants.
    platypus, Nov 16, 2006
  18. Well, he must have been doing something wrong, to drive two BMW shops
    into bankruptcy, one after the other.
    The Older Gentleman, Nov 16, 2006
  19. Jeremy
    Charlie Guest
    Or, alternatively, in Lozzo's view he must have been doing something right.
    Prace bets now for blave attempt on hat-tlick.
    Charlie, Nov 17, 2006
  20. Jeremy
    Charlie says...
    Hurrah for sensibility
    Lozzo
    GSF600SW (broked)
    Lozzo, Nov 17, 2006
