BMW R1100S ABS Indicator lights
Discussion in 'UK Motorcycles' started by DJ, Jan 11, 2004.
  1. DJ
    DJ Guest
    I have a 1999 BMW R1100S - Does anyone know what the alternating red
    ABS indicator lights mean and why they are blinking upon start up but
    tend to go off after about 20-30 mins of riding?
    Thanks!
    DJ
    DJ, Jan 11, 2004
  2. the alternating lights mean there is no ABS function operative. This is
    usually down to low battery charge. As you ride along the bike will put
    some charge back into the battery hence disappearance of flashing
    lights. In my experience with my GS the lights continue to flash all the
    time and will only reset if I stop, cut the engine and then restart.
    This resets the ABS circuit - assuming there is sufficient charge. At
    stand still you will get both light flashing together until you set off
    and the "clunk" noise happens that means the ABS is set.
    Paul Corfield, Jan 11, 2004
  3. DJ
    ^..^ Look we are even offering the same sort of advice now...
    Hog, Jan 11, 2004
  4. DJ
    there's a lot if it about :)
    wessie, Jan 11, 2004
