Hi All and thanks for any help you can provide. I have a used 2000 GS and the cat has been burned since I purchased the bike. Before I replace the cat I want to make sure the HEGO/computer is operating correctly as that is likely the cause. After diagnosing the original HEGO and noting the voltage signal never went above 0.15 volts I replaced the HEGO. and it is still outputting the same voltage. I haven't replaced the computer but it is likely working properly. Does anyone know what I may be missing in my diagnosis? Or what the cause of this may be? My tests have all been done at idle, but I would think the engine should output a rich mix at some point, especially at startup. Thanks, Dave
