I could use some advice on this subject. I followed Moto-Binns (very helpful UK company), suggestion to pull back the crankshaft before removing the flywheel. (Removing the alternator stator and pulling a strap around the front end of the crankshaft). This I think, is to stop the rear thrust bearing from coming loose. However, after removing the flywheel, I found that the thrust bearing had fallen backwards off its two pegs! It replaced quite easily, I carefully pulled out the old seal and tapped the new one in to the same position (flush to the crankcase), as advised because it's the same length as the old one. This means of course that there would still be space for the thrust bearing to dislodge, until the flywheel is bolted up, and you can't see if this happens when you re-fit the flywheel. Re-fitting is awkward with hardly any clearance to the clutch housing. The flywheel felt and appeared to locate squarely and firmly on the end of the crankshaft and the bolts seemed to tighten up evenly and solid, if you know what I mean, and I seem to have the same very small amount of end float. Should I still be concerned? John
