BMW1200gs
Discussion in 'Australian Motorcycles' started by Michael Chester, Oct 28, 2004.
  1. Has anybody heard of any "teeth troubles" with the new BMW1200GS, I've had a
    ride and liked very much, (I must be getting menopause), great all rounder,
    Mick Chester
    Cootamundra
  2. Michael Chester
    Nev.. Guest
    What's going on in aus.moto nowadays??? You're the 2nd ZX12R rider (ok
    former rider) to take the R1200GS out for a spin and like it very much. I was
    the first :) http://www.evilurl.com/PUSSYPEEporno
    Nev..
    '03 ZX12R
    Nev.., Oct 28, 2004
  3. The only thing I've heard of so far is some pannier mountings breaking quite
    easily.
    Disregarding what the press say and how good the bike is to ride; this is a
    virtually all-new BMW, new motor, new gearbox, new paralever, new sealed
    non-servicable rear drive. Going by BMWs previous releases of new
    technology and what's happened to the bikes I've had, I'd be letting someone
    else do the experimenting unless I knew the bike was being sold at the
    expiry of the warranty period and had no intention of keeping it for
    200,000kms. They make great engines but often seem to stuggle with the
    running gear.
    Al
    Alan Pennykid, Oct 28, 2004
  4. Michael Chester
    glitch1 Guest
    Can't remember exactly what they were, but there are 2 issues with the GS12
    currently...
    Let's see if BM is reacting to it or go into the usual "denial mode"
    (problems? what problems? never heard that before...)
    Check around the usual N/G traps.
    cheers
    pete
    glitch1, Oct 28, 2004
  5. Michael Chester
    phil Guest
    Yes there have been some. The few i have heard of.. the quick connect wiring
    to the fuel pump can fill with water... a gear box seal & a final drive seal
    have failed but were picked up by the owner under warrenty prior to damage.
    End transmission ...i can hear the black choppers closing as i type & there
    are 2 doods that look like they are from pulp fiction knocking at the door.
    phil, Oct 29, 2004
  6. Michael Chester
    Conehead Guest
    Perhaps you two are the only ones prepared to admit to it.
    Conehead, Oct 29, 2004
  7. Michael Chester
    IK Guest
    Are those roads wet, Nev?
    (this is where I admit to having hankered for an adventure-tourer for yonks
    now, almost to the point where one might become the next addition to the
    garage)
    IK, Oct 29, 2004
  8. Michael Chester
    glitch1 Guest
    ....and that is when the problem really starts. After a while you'll hardly
    want to ride anything else.
    Not for any length of time, anyway.
    Been there, got stuck :) Still don't regret it...
    cheers
    pete
    glitch1, Oct 29, 2004
  9. The ZX12 had to go, 4 years without a speeding ticket (pushing my luck) ,
    17000k and 6 rear tyres (I just couldn't help it) it costs less to tyre my
    truck than the bike.
    So we come to the GS12, I have talked to few dealers, but as they are still
    selling more than they can get, they (dealers) don't want to "deal", I 'll
    sit tight for a year,
    DO I have to become a uslesscitizen member now??
    Thanks all for return posts
    mick chester
    Michael Chester, Oct 29, 2004
  10. Michael Chester
    Boxer Guest
    Just don't tow a caravan with them.
    Boxer
    Boxer, Oct 29, 2004
  11. Way before the camper
    K100RT (Mine), shedding teeth on crownwheel, sold bike
    R100GS (Mine):Broken 5th gear, replace all gearbox bearings(1), Front
    universal joint failure(2), all at less than 65,000kms
    K75s(Maries) stripped clutch centre and gearbox input shaft(1), Stripped
    driveshaft spline(2), Stripped driveshaft spline and pinion spline on
    diff(3)
    K100RT sidecar, replaced worn driveshaft before the spline failed, one rear
    output shaft bearing (this bike did big kms, the repairs were reasonable for
    its use)
    R1100R (Mine, Maries and back to mine) Oil weeping down the clutch pushrod
    past a seal causing a slipping clutch plate @ 40,000kms, major gearbox
    rebuild at 115,000kms
    R1100GS (Mine) Oil weeping down the clutch pushrod past a seal causing a
    slipping clutch plate (discovered first time I took it away, it didnt show
    on the test ride, covered under warranty. The bike had done around
    60,000kms) , only had it six months.
    R1150R (Marie) Leaking diff oil seal (fixed under warranty), stripped clutch
    spline and input shaft at 6 weeks after 12 month warranty had run out, no
    assistance given as the bike had a towbar. The bike now has another leaking
    diff oil seal at around 70,000kms This bike has towed a trailer, but behind
    one person only, total weight of rider/trailer probably around 190kg.
    K100RS sidecar(mine), diff rebuild and new driveshaft (UJ failure), this
    bike did work hard and the diff was used to begin with. I couldnt complain
    about the service this bike gave me.
    Most of these bikes never towed a thing John, and I dont treat them that
    bad. I just think that BMWs image of absolute reliability is ill-deserved.
    Especially the attitude when they release new driveline
    components/technology, it fails and all you get is "We've never seen that
    happen before."
    Buy a BMW by all means (and I'll probably buy another one day), just don't
    buy the first one out of the showroom unless you are expecting to get rid of
    it when the warranty expires. Or let it run a few years before buying till
    people know the fixes for BMWs design fuckups (if they could have rebuilt an
    R100GS driveshaft in 1993 like they can now, I would have had it a lot
    longer, no way was I paying $1000 for a driveshaft just because you couldnt
    replace the uni). The 1200GS has an all-new gearbox and an all new
    Paralever, how many new gearboxes have they released since the start of the
    R1100 series to try to get them right?
    Al
    Alan Pennykid, Oct 30, 2004
  12. Got a Yamaha now. (and one BM K100 in the backyard, once it get it going
    again, I'll just ride it till it stops, should be a while).
    Al
  13. Michael Chester
    IK Guest
    (in a voice of despair)
    And still you persist with the things... why, Al, why?
    IK, Oct 30, 2004
  14. Michael Chester
    phil Guest
    What he said. In saying that i have an oilhead with 70K (not much i know)
    on it that has never so much as burped....its a good one, & when you get a
    good one its sweet. But no way in hell would i be buying a 1st model. Mine
    is the very last of the 1100's.
    phil, Oct 30, 2004
  15. Michael Chester
    Nev.. Guest
    Yeah, the ones which look wet are wet. Most of the Grand Ridge road was wet
    from rain earlier that morning and a few brief showers while I was there...
    especially the dirt sections.. as evidenced by our unplanned lie down in the
    mud. Pillion took about 15 minutes of video footage looking over my shoulder
    and it really surprised me how fast I was going. Looks a lot faster than it
    felt when I was riding it... stupidly fast in some places, but I suppose the
    camera having tunnel vision and not being able to look through corners does
    change the perspective somewhat.
    Nev..
    '03 ZX12R
    Nev.., Oct 31, 2004
  16. Michael Chester
    John Littler Guest
    You need a Guzzi* you do !
    JL
    (*Quota - well you're one of the few people I know tall enough to ride
    the damn thing !)
    John Littler, Oct 31, 2004
  17. John Littler and Quota, what a picture?
    http://home.wanadoo.nl/menk/_f650/Rahier.gif
    Al
    Alan Pennykid, Nov 1, 2004
  18. Pisshead Pete, Nov 1, 2004
  19. Michael Chester
    IK Guest
    IK, Nov 2, 2004
  20. Michael Chester
    John Littler Guest
    John Littler, Nov 2, 2004
Similar Threads
Loading...
