Bollocks
Discussion in 'UK Motorcycles' started by Paul Carmichael, Jun 27, 2008.
  1. What'll it be then?
    Paul Carmichael, Jun 28, 2008
  2. Paul Carmichael
    Eddie Guest
    Hmmm... I need something healthy: a very large Bloody Mary, please.
    Happy now?
    Eddie, Jun 28, 2008
  3. Heh. I now have to earn how to use Agent. That last post lacked a sig. I
    see one can have "personas" but it's not yet obvious how to use them in
    different groups etc. The help system doesn't work as the gherkin HTML
    thing doesn't work. Guess I'll have to stick it on a windows box to
    investigate.
    Paul.
    CBR1100XX SuperBlackbird (Buen mueble de patio)
    And a pushbike of some sort.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
    http://obscuredomainname.org
  4. Paul Carmichael
    Colin Irvine Guest
    If it's like older versions there'll be a "Groups" menu in which you
    can set properties for each ng, including which signature to use.
    Colin Irvine, Jun 28, 2008
  5. There's a million options, but I can't see anything like that as yet.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
  6. Paul Carmichael
    YTC#1 Guest
    The 32/64 bitness does not generally give more performance, in many cases
    64bit can be slower. What it does give is a larger address space, so more
    memory can be accessed and larger files etc on disks can be held.
    YTC#1, Jun 28, 2008
  7. Paul Carmichael
    YTC#1 Guest
    +1
    YTC#1, Jun 28, 2008
  8. Erm, after a couple of looks at it, I've come to the conclusion that it's
    way over-featured for me. Fact is, I can't figure out how to use it.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
    Paul Carmichael, Jun 29, 2008
  9. Paul Carmichael
    Eddie Guest
    "There's no pleasing some people."
    So, which newsreader (Windows/Linux/other) *do* you like?
    Eddie, Jun 29, 2008
  10. I liked Xananews the best I think. I had a problem with it on this ng,
    but that may have possibly been resolved by clearouts/tidying up. The
    last time I tried it on 98 it kept crashing (has some sort of debug
    module which is supposed to send an email to the authour, but after 2
    months the email bounces back). The same thing is happening now under
    wine. This pan thing isn't too bad, but it has some annoying problems
    like it doesn't remember what's been read and it doesn't group threads
    properly - I assume this has something to do with fetching stuff off
    different servers and not recognising it as the same thread.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
  11. Paul Carmichael
    Derek Turner Guest
    You could very well be right about that. I'm using it both on mint and on
    my occasional boots into windows, For me it's working perfectly and I
    especially like the 'ignore author' and 'ignore thread' features.
    However, I am using just the one (German) server.
    Derek Turner, Jun 29, 2008
  12. So you don't recommend I try Mint in pace of Ubuntu then?
    Steve Fitzgerald, Jun 29, 2008
  13. I'm only using the very same server. I was referring to the way articles
    propagate between the servers. Perhaps if someone posts a message to one
    server, then another server picks it up through normal propagation, there
    is something different in the headers that all other newsreaders ignore.
    With the result that I see replies to the same thread in several separate
    threads. I know we are seeing something similar to this because of "Old
    Cheesey", but this is something different.
    And when I restart the newsreader all the articles are marked as unread.
    Is this because it's failing to write something as a result of write
    permissions? I see quite a few programs silently fail for this reason.
    Then one does a google search and eventually someone says "you have to go
    into the /etc/bollocks/.arse directory and type chmod 7777 wibble and
    then it will work". What a pain.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
  14. No idea. This Derek chappy seems to be a bit more experienced than me on
    this subject. I just know that this machine is now stable and fast and I
    ain't going to mess with it.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
  15. Well, I got Ubuntu installed here and it just worked, as you said. I
    considered trying Mint as it's been widely hawked about here.
    I think I'll stick with Ubuntu.
    Now, I'm wanting to run an email server thingy (one of those things that
    does email groups but doesn't need to do much else) and would like to
    use this here Ubuntu machine. Any help for the clueless?
  16. Maybe a thread with a different name to "Bollocks" might attract the
    relevant geeks? Also the ubuntu forums are quite keenly monitored.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
  17. Paul Carmichael
    Eddie Guest
    You can use mailman, but I think it might need a local mail server.
    Eddie, Jun 29, 2008
  18. It does. That's what I run at home for binary access (under Ubuntu64)
    Phil.
    Phil Launchbury, Jun 30, 2008
  19. Mailman? Listserv?
    I use qmail and ezmlm at home but it's not for the faint-hearted..
    Phil
  20. Easy enough to set up..
    "apt-get install postfix" would do it.
    Phil
