Bombardier
Discussion in 'UK Motorcycles' started by Tunku, Apr 11, 2007.
  1. Tunku
    Tunku Guest
    My son's best friend, a 20 y/o marine has just got hold of one of these.
    Apparently off a bloke in a pub.
    http://www.rememuseum.org.uk/vehicles/dom/vehcanam.htm
    It's completely original with all parts present, and will try to fire but
    dies. I haven't had a chance to see it yet, but it appears to use a Rotax
    250cc engine. Could it be the usual "shit in the carbs" :)
    If anyone has any info, I would be most grateful.
    Tunku, Apr 11, 2007
  2. Usual stuff, plug, carb, timing (electronic box).
    They're quite tough things and usually good starters, but if this one's
    been lying around for a while it's likely just crap fuel or gummed up
    carb.
    Grimly Curmudgeon, Apr 12, 2007
  3. Tunku
    Tunku wrote:
    [snip on-topic stuff]
    Oh, I had hoped this post was going to be Charles Wells related.
    *disappointed*
    CT, Apr 12, 2007
  4. Tunku
    peter Guest
    IIRC basically the same disc valve Rotax motor as in my old
    'Rotarini'. In that case the engine was from a 250 SWM crosser.
    That had a nasty habit of failed ignition charging coils. The windings
    are very thin wire and can break down when hot (the vibes don't help).
    Sometimes it would start when stone cold then run for a minute or so.
    I replaced mine with an original part sourced from Andover Norton.
    When that failed I got it rewound by Westcountry Windings. I always
    used to take a spare to race meetings. Even worse, when it died it
    would sometimes put the ignition timing right out first and eat the
    piston.
    Could be a blocked jet , but try putting a multimeter across the
    output from the windings. If you get a healthy voltage, the motor
    starts, but then the voltage drops and it stops running that suggests
    the charging coil is the problem.
    peter, Apr 12, 2007
  5. Tunku
    Lucifer Guest
    Hehe so did I
    Ditto.
    Lucifer, Apr 12, 2007
  6. Tunku
    Tunku Guest
    wrote in
    Cheers everyone - I will take a gander at it with all my 25 years ago
    forgotten about 2 Stroke knowledge. Last 2 stroker I had was an Ariel
    Leader :)
    Quite looking forward to it actually.
    Tunku, Apr 12, 2007
Similar Threads
Loading...
