BOTAFOT epilog
Discussion in 'UK Motorcycles' started by Dan L, Oct 9, 2005.
  1. Dan L
    Dan L Guest
    Heh, really glad you made it Nick, you seem to ride at my pace too, which is
    a bonus as I usually end up bringing up the rear.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Oct 9, 2005
  2. Dan L
    snip>
    No editing required.
    Andy Bonwick, Oct 9, 2005
  3. Dan L
    muddy Guest
    *snort*
    muddy, Oct 9, 2005
  4. Dan L
    BGN Guest
    I've been trying to formulate a reply for the last five minutes.
    BGN, Oct 9, 2005
  5. In uk.rec.motorcycles, BGN amazed us all with this pearl of wisdom:
    What did you come up with?
    Whinging Courier, Oct 9, 2005
  6. Dan L
    Dan L Guest
    Heh, thought that'd raise a few titters
    Dan L (Oldbloke)
    Dan L, Oct 9, 2005
  7. Dan L
    Dan L Guest
    A bit fucking expensive on dial-up I'd have thought then
    Dan L (Oldbloke)
    Dan L, Oct 9, 2005
  8. Dan L
    BGN Guest
    I'm only paying a pound for a month :)
    BGN, Oct 9, 2005
  9. Dan L
    BGN Guest
    Only "boggle"
    BGN, Oct 9, 2005
  10. Dan L
    dwb Guest
    Daz and Bonners I think you're right - Dan and I, it's probably only 50'ish
    [1]and your bike is a lot lighter than either of ours I suspect.
    [1] Strom is +- 100 bhp , 210kgs + me (75kg).
    Ta - it also means an insurance renewal :( :)
    That would be telling.
    dwb, Oct 9, 2005
  11. Dan L
    dwb Guest
    I'd had enough rear action after the first stint.
    dwb, Oct 9, 2005
  12. Dan L
    dwb Guest
    <smug>
    I didn't notice the cold, other than via the SCCS [1] - heated grips and two
    fleeces + wind stopper top rock :)
    [1] Suzuki Crotch Cooling System
    dwb, Oct 9, 2005
  13. Dan L
    I'm not so sure as it appears to have become oil-phobic and is chucking
    it out the catch tank overflow.
    It's always done this at high revs over extended time but it's now doing
    it at lower speeds and shorter periods.
    The flat out, flat on the tank run from Brighton - Aylesbury in a little
    over an hour and a bit needed a full litre (in a 3l capacity sump) just
    to get it on the bottom of the dipstick.
    It chucked a load out on the way back and I wasn't even caning it. Just
    sat at 90 ish.
    Investigations are required.
    sweller, Oct 10, 2005
  14. Dan L
    BGN Guest
    BHP is 50ish on the ER-5, it weighs 179Kg + me (114Kg)
    I was pleased that even when I had SeanH from Brighton go pillion on
    it for an extended hoon a week or two ago it still managed to get to
    100mph without issue.
    Hopefully cheaper!
    BGN, Oct 10, 2005
  15. Dan L
    Sounds like compression escaping into the crankcase, down the bores or
    exhaust valve guides.
    platypus, Oct 10, 2005
  16. Dan L
    Well the only cure known for that is high compression forged pistons and
    40mm valves in a ported head.
  17. Dan L
    Guzzi's have a reputation for being heavy breathers and the breather
    system not being quite up to the job.
    However, mine has the large breather box and sump extension (same oil,
    greater volume of air in the crankcase) so shouldn't suffer from it.
    I've always been a bit suspicious of my dipstick as it doesn't have the
    standard type - I may be unknowingly overfilling although I don't think
    so as an oil change seems about right on the stick IYSWIM - but what's
    it's been throwing out is more than a bit of overfilling.
    I'll get my hands on a standard deep sump dipstick to prove this one way
    or another.
    It's certainly been susceptible to blowing it out in the time I've had
    the bike (it now has at least 100,000 miles on it) but I really need to
    do something about it. If I can't flat stick it for hours at a time it's
    not much use.
    Happily replacement HC piston ass. (and I assume these include rings) are
    £29 each. Bores are Nickasil so should be ok.
    I'll speak to Gary at Wessons to discuss testing the crankcase pressure.
  18. Dan L
    Kiran Guest
    Presumably so you can sell it to buy a 9R?
    Kiran
    Kiran, Oct 10, 2005
  19. Dan L
    Ben Blaney Guest
    That needed to be played with an absolutely straight bat. I think you
    might *just* have got away with it.
    Ben Blaney, Oct 10, 2005
  20. In uk.rec.motorcycles, Bear amazed us all with this pearl of wisdom:
    ITYM "Razzler" and anyway, I've got the internet now ;)
    Whinging Courier, Oct 10, 2005
