BP Petrol.
Discussion in 'UK Motorcycles' started by Cab, Aug 20, 2005.
  1. Cab
    Cab Guest
    Anyone got experience of using their new fangled stuff? Is it any good?
    Is it to be avoided at all costs?
    Cab, Aug 20, 2005
  2. Cab
    Without a knock sensor and turbo, I don't think you'll get any
    perfomance increase in power. I did notice an altering in the engine
    vibes from both the CG125 and the Bandit though.
    Muck, Aug 20, 2005
  3. Cab
    Cab says...
    Can't say I've noticed or really give a **** tbh. Petrol is petrol to
    me. Bike needs it, so I fill it up wherever I am.
    Lozzo, Aug 20, 2005
  4. Cab
    Wik Guest
    I know they weren't as helpful about providing specifications,
    specifically the RON octane rating, of their "Ultimate" as Shell were
    about their "Optimax".[1]
    This had the net effect of me thinking "It's not as good as Optimax"
    whether that be the case or not.
    If a manufacturer isn't prepared to back up their performance claims
    with some good, old-fashioned facts then I'm not going to gamble an
    expensive tuned engine by putting their product in it. Simply saying
    "it's similar to Optimax" isn't enough.
    Wik, Aug 20, 2005
  5. Lozzo wrote
    12 eyes he speak the truth.
    steve auvache, Aug 20, 2005
  6. Cab
    Cab Guest
    I've felt the same way. They've no explanations as to what it is, what
    it does or why it's more expensive.
    It got me thinking though, after one of the lurkers on the NG told me
    that he gets better mileage out of it and that it's worth the extra few
    pence/cents.
    Cab, Aug 20, 2005
  7. Cab
    Wik Guest
    Well, indeed...
    What's the availability of "Optimax" in France? I recollect seeing more
    BP stations over there than Shell ones, certainly seem top be more of
    them in the UK...
    Wik, Aug 20, 2005
  8. Cab
    Cab Guest
    I don't know really. There are quite a lot of BP stations around Paris,
    but not so many Shell stations. I don't know if this is a nationwide
    trend.
    Anyway, the only Shell station near to where I live, I don't use. Not
    since they refused to serve me as they wanted cash up front.
    Cab, Aug 20, 2005
  9. Cab
    mike bothe Guest
    You don't have 'pay at the pump' then? anyway, shell is shite. It makes
    the SV hard to start among other problems.
    mike bothe, Aug 20, 2005
  10. Cab
    Cab Guest
    There are some, but not many, in town. They're mostly in the sticks,
    IME.
    Cab, Aug 20, 2005
  11. Cab
    mike bothe Guest
    Ah, well; it is Paris after all.
  12. Cab
    Andy Hewitt Guest
    FWIW, I can only comment on what I see at work, as I never use Shell or
    BP (if I can help it), based on our observations of faults occuring.
    The additive enriched fuels *seem* to offer a very quick improvement in
    performance - whether real or perceived I cannot say. My only personal
    experience of using Shell was of poor running and stalling.
    What we are seeing more of now though is engine management faults. Most
    are O2 sensor failures, EGR valve failures and unexplainable misfires
    [1].
    When these components are removed they are usually found to be coated in
    a sticky black soot, very often linked to vehicles that are being run on
    Shell fuel. The BP stuff hasn't been around long enough to obtain data
    as yet.
    In the worst cases we have found valves burning out too - even on the
    legendary VTEC Honda engines - that's how bad it can be.
    It's now so bad that we are advising customers to avoid using fuels with
    additives, and stick to plain fuels - like Jet or Total. A major
    additives supplier is also now making an 'anti-additive' additive (yes
    really!). We are finding some success in using the newest Forte' Fuel
    Treatment, which is not like a normal fuel system cleaner, but is a
    contaminant neutraliser [2].
    The way I see it is that the additives are probably the equivalent of a
    £3 bottle of stuff off the shelf. It costs somewhere between 30 and 100
    million pounds to design, develop and build an engine. An engine,
    particularly in the case of Honda and Toyota, and many others, that will
    have been designed to burn standard fuel as efficiently as possible.
    You get to the pump, and that fuel is *not* the same as the stuff they
    developed the engine for.
    As for fuel economy and savings, has anyone actually worked it out?
    I just did. Assume an average of 40mpg on standard fuel, and a gain of
    2mpg on Optimax. I priced the fuel at 4p/litre difference, 90.9p and
    94.9p around here. Over 12000 miles it will cost you £1230 for standard
    fuel, and £1238 for Optimax. That is assuming that you do actually get
    better consumption at all.
    [1] they can also produce fault codes.
    [2] sorry if that sounds like an advert.
    Andy Hewitt, Aug 20, 2005
  13. Cab
    Kiran Guest
    Dunno, never used it. Still, be careful with the pumps, cos they're all (or
    were) the same shade of blue including the diesel ones so could be easy to
    fill up with the wrong fuel. Chap on a beemer forum filled his 330d with
    petrol instead of diesel [1]. Caused £3k damage to his engine, which BP
    footed the bill for.
    [1] It might have been the other way round, i forget.
    Kiran, Aug 21, 2005
  14. Cab
    Cab Guest
    Oh, nice reply. Thanks. I think I'll stick with the regular smelly
    stuff.
    Cab, Aug 21, 2005
  15. Cab
    Cab Guest
    I tend to use 95 anyway and don't bother using 98. As I said, one of
    the lurkers told me that he had better fuel consumption after using it
    the Ultimate.
    I was wondering whether it's worth a try or not. Would it produce
    beneficial results? Better for the environment or not?
    Cab, Aug 21, 2005
  16. Cab
    Andy Hewitt Guest
    Almost certainly not. In an engine that is not able to use the extra
    octane, you will end up with some unburnt fuel being passed through the
    system. A higher octane fuel needs a longer burn cycle, if the engine
    does not offer that, then not all of the fuel will get burnt.
    Andy Hewitt, Aug 21, 2005
  17. Cab
    Andy Hewitt Guest
    Now for the short reply.
    "snake oil" ;-)
  18. Cab
    Eiron Guest
    Don't let the facts spoil a good theory.
    Eiron, Aug 21, 2005
  19. <VVBG>
    Magnet-onna-fuel line.
    The Older Gentleman, Aug 21, 2005
  20. Cab
    Andy Hewitt Guest
    One of my customers at Alfa sold those. It was mysteriously removed from
    his own car when it came in for warranty repairs.
