Brake fluid
Discussion in 'Australian Motorcycles' started by CX, Aug 8, 2003.
  1. CX
    CX Guest
    Installing braided lines as part of the clean up after dropping it. Anyone
    have a preferred dot 4 fluid, or are they all much of a muchness?
    Cheers,
    Andrew
    CX, Aug 8, 2003
  2. CX
    FuTAnT Guest
    Motul DOT5.1 is kinda groovy 'cause it's almost colourless when new, and it's a silicone based fluid. mmmm.
    Cam
    '00 ZX6R
    FuTAnT, Aug 9, 2003
  3. CX
    CX Guest
    Heard some odd things about dot 5... I'm guessing you've used it, is there
    any noticable advantage/disadvantage to the stuff?
    I'm aware that mixing the stuff with 3/4 is a bad idea.
    CX, Aug 9, 2003
  4. CX
    CoRkS Guest
    dot 4 is fine i use silkolene semi synthetic
    isnt dot 5 only really supposed to be used for racing applications ?????
    something about takes to long to get hot or too hydroscopic or something
    CoRkS, Aug 12, 2003
  5. CX
    Theo Bekkers Guest
    "John Littler" wrote
    Dot 5 can cause swelling of master and slave cylinder seals. If you
    use it in a '70's or '80's Guzzi both your master cylinders will
    suffer from seal swell and wont return all the way. It also caused
    problems with rotting seals in Toyota Corona clutch slave cylinders.
    I didn't try it in my current Guzzi.
    Theo
    Theo Bekkers, Aug 12, 2003
  6. CX
    Theo Bekkers Guest
    "CoRkS" wrote
    something
    Dot 5 is not hygroscopic and that is a good thing. It can operate at
    higher temperatures and that is a good thing. It doesn't attack your
    paintwork and that is also a good thing.
    Eating your seals is a very very bad thing. (That's the fluid eating
    the seals corks, not you. You shouldn't eat seals either).
    Theo
    A hydroscope is an instrument for observing things underwater. Seals
    maybe?
  7. CX
    conehead Guest
    Don't blow seals, either, corks
    conehead, Aug 12, 2003
  8. CX
    Nev.. Guest
    It's ok... He just hunts them for sport.. not food.
    Nev..
    '02 CBR1100XX #2
    Nev.., Aug 12, 2003
  9. CX
    FuTAnT Guest
    Yup, I've used the DOT5 fluid with great results. Used it in my ZX6R's etc. Bled out the old, and in with the
    new. I think the silicone based fluids are a little less prone to taking on water etc, and may even offer a
    bit less friction. Definately no bad points that I've come across so far anyway. I was just looking for some
    gucci fluid and this seemed to take the cake. As far as a comparison, there's probably not *that* much
    difference, but maybe in high temp apps or something is where the DOT5 comes into it's own? It's advertised as
    more of a racing fluid, so you'de think there's something about it that makes it *the shit*.
    Cam
    '00 ZX6R
    FuTAnT, Aug 12, 2003
  10. CX
    waz Guest
    Brake Fluids
    Thanks to Dave Zeckhausen :
    Lets look at what the DOT ratings mean. The table below shows the
    MINIMUM wet and dry boiling points for DOT 2, 3, 4, and 5 brake fluid
    in degrees Fahrenheit.
    DOT 2 DOT 3 DOT 4 DOT 5
    Dry Boiling point 374 401 446 500
    Wet boiling point 284 311 356
    The DOT 2 spec is for drum brakes and is obsolete. If you have any
    DOT 2 in your garage, throw it away! DOT 5 is for silicone brake
    fluid. Silicone brake fluid (DOT 5) should be avoided because it is
    not compatible with regular brake fluid, it is hard to pour without
    introducing bubbles and thus results in soft pedal feel, and moisture
    still gets into your system and will pool in low areas like your
    callipers and encourage rapid corrosion. STAY AWAY!
    That leaves DOT 3 and DOT 4 fluids. These fluids are compatible with
    each other and may be interchanged or mixed with no ill effects.
    from
    http://www.shotimes.com/SHO3brakefluid.html
    waz, Aug 13, 2003
  11. CX
    CoRkS Guest
    wot if i wuz a eskimo, wood it be ok to eat seals then
    CoRkS, Aug 13, 2003
  12. CX
    CoRkS Guest
    its okay just as long as you eat them ;-)
    CoRkS, Aug 13, 2003
  13. CX
    Theo Bekkers Guest
    "CoRkS" wrote
    I think it was an Eskimo working for NASA that caused the shuttle problem.
    Theo
    Theo Bekkers, Aug 14, 2003
  14. CX
    Doug Cox Guest
    Using your Inuition?...
    Doug Cox.
    Work to ride, Ride to work...
    Doug Cox, Aug 14, 2003
  15. CX
    [applause]
    Clem
    Knobdoodle, Aug 14, 2003
  16. CX
    Theo Bekkers Guest
    "Doug Cox" wrote
    Wow! Well done! (for a young bloke).
    Theo
