Brake Question
Discussion in 'Australian Motorcycles' started by Michael Chester, Feb 9, 2004.
  1. Are brake lever / master cylinder assemblies ( the bit on the handle bar )
    matched set with the caliper , i.e. can I put a Kawasaki lever assembly on a
    Honda Caliper ? if the threads and bolts all fit, or is there a dark secret
    of compatibility
    Regards
    Michael Chester
    Cootamundra
  2. Michael Chester
    smack Guest
    I met your wife. you were away...
    Had a pie at the shop next door
    smack
    smack, Feb 9, 2004
  3. In aus.motorcycles on Mon, 09 Feb 2004 07:01:09 GMT
    Sometimes the slot the lever goes in is wider or narrower than the lever
    you have. Wider isn't all that much of a problem except it rattles.
    Sometimes the ends of the levers are different lengths or shapes, and
    won't engage whatever they are supposed to engage at the right angle, or
    push soemthing in far enough.
    all you can do is suck it and see... if you have a lever to match
    against, then eyeball the differences and peer into the master cylinder
    slot to see what it has to engage.
    Zebee
    Zebee Johnstone, Feb 9, 2004
  4. Michael Chester
    sharkey Guest
    Piston diameter (and possibly stroke).
    -----sharks
    sharkey, Feb 9, 2004
  5. Michael Chester
    Chesterfield Guest
    Yes she said you were in for 15 minutes !!!
    sorry I missed you, caps and jumper should be ready this week.
    Michael Chester
    Chesterfield, Feb 9, 2004
  6. Michael Chester
    Naah; all the Jap stuff is virtually identical 5/8th inch diameter piston.
    You'd be pretty unlucky to find one that doesn't work.
    Clem
    (actually; all the non-jap stuff probably is too!)
    Knobdoodle, Feb 9, 2004
  7. Michael Chester
    smack Guest
    ta mate
    smack, Feb 9, 2004
  8. You sly prick....
    Postman Pat
    Pat Heslewood, Feb 9, 2004
  9. Wouldn't have done him any good, he looks like a Yeti at the moment...
    Kevin Gleeson
    Imagine It
    West Hobart
    Tasmania Australia
    www.imagine-it.com.au
    Kevin Gleeson, Feb 9, 2004
  10. Michael Chester
    smack Guest
    do not! I look like a Tasmanian. I R gonna change my name to Ian Bread
    smack, Feb 9, 2004
  11. Oi! You're at work. Pay attention to what's on air ....
    Jeezuz - posting to ng's on my 8 cents a day ....
    Kevin Gleeson
    Imagine It
    West Hobart
    Tasmania Australia
  12. Michael Chester
    glitch1 Guest
    Make sure the line-diameter is the same and both units were set out to
    service the same number of discs (i.e. don't use a master cyl. designed for
    a single disc front end on a twin-disc front end, the other way around
    should be fine).
    As a general rule, it's usually safer to use a bigger (volume) master-cyl
    than the original one.
    cheers
    pete
    glitch1, Feb 9, 2004
  13. Michael Chester
    Conehead Guest
    Goddamn hippie yeti yuppie
    Conehead
    Conehead, Feb 10, 2004
  14. I was going to say as long as they have the same power, you don't want to
    have a cylinder that at fill squirt only engages the caliper 1/2 on. being
    hydraulic big to small its unlikely tho..
    www.mad-biker.com who knows nuffin about nuffin
    Mad-Biker.com, Feb 10, 2004
  15. Michael Chester
    Chesterfield Guest
    Thanks all, I'll give it a go, I've got a YZ125 1988 front end on the old
    IT490, so i'm looking to make the feel and power a bit different.
    Chesterfield, Feb 10, 2004
  16. On 9/2/04 7:22 PM, in article
    CrHVb.48724$, "Chesterfield"
    <> decided to come out from under the bed and
    slurred:
    Jeez, he was still boasting when he got to my place!
    Hammo
    Hamish Alker-Jones, Feb 11, 2004
  17. Ooooohhhhhhh, I bet it isn't........
    Hammo
  18. Hammo wins a beer! 9/16 and 11/16, single and twin disc.
    Pisshead Pete, Feb 12, 2004
  19. Michael Chester
    Bloody friggin' American non-jap stuff!!
    I was talking about European non-Jap stuff!
    Clem
    Knobdoodle, Feb 12, 2004
