Brake question
Discussion in 'Australian Motorcycles' started by Yeebok, Jan 1, 2009.
  1. Yeebok
    Yeebok Guest
    You know I know **** all about mechanical stuff so here's the situation.
    Went for a ride to wauchope today with plans to go down via Tele point.
    Anyway I got to Wauchope and turned off onto Pembroke Road but then my
    rear brake was 'on' - the bike'd accelerate sure, but it was braking the
    whole time. I reckon I travelled 400m before I worked out why I was
    slowing down got to the side of the road and stopped.
    The rear brake was on almost enough to lock the wheel when stationary,
    but with the bike going of course it was just enough pressure to slow
    the bike down and generate lots of heat.Even though the rear brake was
    smoking I was still stupid enough to touch the disc and have 5 white
    fingertips to prove it was hot (typing's a bastard at the mo). I tried
    lifting the pedal forcibly but that didn't release the brake.
    So not sure whether it 'stuck' on or not but about 15 minutes later it
    was free enough to ride, and I went home without using the rear brake.
    With it being NY and cleaning up after last night I have not had chance
    to check the state of the fluid but there's enough in there from looking
    at the outside.
    Any ideas on where I should start to look ?
    Yeebok, Jan 1, 2009
  2. In aus.motorcycles on Thu, 01 Jan 2009 20:04:06 +1100
    If it did that because you used the rear brake, then it didn't free
    up.
    It could be some form of hydraulic lock, but I feel it unlikely.
    It could be a sticky piston where you work the pedal, it pushes the
    piston into the fluid, and the piston stays stuck and then slowly
    works its way free.
    It could be that the pistons behind the brake pads are sticky so you
    work the pedal, the fluid pushes them to have pads contact disk, but
    they don't move back.
    No idea how you'd check it to determine which it might be.
    Zebee
    - who knows exactly what to do if it was a proper drum rear. This
    new fangled stuff....
    Zebee Johnstone, Jan 1, 2009
  3. Yeebok
    Yeebok Guest
    So if it's sticking is it possibly something simple like marmafluid
    (like Clem was on about before) - or something 'foreign' ?
    Yeebok, Jan 1, 2009
  4. Yeebok
    Boxer Guest
    Sounds like corrosion in the rear caliper, remove disassemble clean fit new
    seal kit reassemble. Problem solved.
    Next!
    Boxe
    Boxer, Jan 1, 2009
  5. You can "sometimes" free up the stuck brake by rolling the bike backwards
    but as Boxer said, take the caliper apart and check for corrosion, either
    white or brown
    clean it up and refill with NEW fluid
    George W Frost, Jan 1, 2009
  6. Yeebok
    Yeebok Guest
    Thanks Peter - no light on, I should have added I did that in my
    roadside testing, so the ideas above are what I'm going to check later
    tonight.
    Yeebok, Jan 2, 2009
