Brakes, fettling of.
Discussion in 'UK Motorcycles' started by Kevin Seal, Sep 29, 2005.
  1. Kevin Seal
    Kevin Seal Guest
    Having stripped and cleaned the calipers/pistons in readiness to fit new
    brake hoses (courtesy of the Busters offer). Are there any trade tips on
    re-assembley of the calipers like filling the calipers with brake fluid
    before putting the pistons back in to make bleeding quicker?
  2. Kevin Seal
    Buy or borrow a Mityvac. That's all you'll need.
    Oh - grease your nipples on reassembly - that helps too.
    Pip, Sep 29, 2005
  3. Kevin Seal
    flash Guest
    Don't use an old Seal.
    flash, Sep 29, 2005
  4. Kevin Seal
    Eddie Guest
    Hmmm... is that wise? Isn't there a possibility of contaminating the
    brake fluid?
    Eddie, Sep 29, 2005
  5. Kevin Seal
    Organoman Guest
    Pip wrote:
    *boggle*
    Organoman, Sep 29, 2005
  6. Kevin Seal
    Only if you pour it over your chest.
    Krusty, Sep 29, 2005
  7. Kevin Seal
    Kevin Seal Guest
    OK, who's local Barnet who can lend me a Mityvac?
    Oooh, Madam!
  8. Kevin Seal
    Kevin Seal Guest
    But I *am* an old Seal!!
  9. Kevin Seal
    flash Guest
    Well at the very least you have to remove any dirt that has accumulated
    around the rim.
    flash, Sep 29, 2005
  10. Kevin Seal
    Kevin Seal Guest
    I let the penguins lick that away.....
  11. Or Uxbridge, for that matter. Looks like I _have_ to get Black Kat
    bled and through MoT now. :-(
    GSX600F, RG250WD, DT175MX-MIA "You Porsche. Me pass!" DoD #484 JKLO#003, 005
    Dr Ivan D. Reid, Sep 29, 2005
  12. Kevin Seal
    Kevin Seal Guest
    <Scratched knuckles and lots of pumping later>
    Well it's all done bar the last few stray air bubbles.
    The lever is reasonably firm, but not as good as it could be. So I'm
    going to try Tog's trick of tying the lever back overnight, and then
    give it a bleeding good kick^H^H^H... I mean a good bleeding again in
    the morning. Shame it's gonna rain or it would have been a nice
    opportunity to go out for a spin.
    In other news, I lost my job last Friday as the recording studio I
    worked at has gone to the wall. It only lasted 18 months under new
    ownership after Sony Music closed it and gave us all the push in
    February 2004. It's a strange feeling to have been made redundant twice
    from effectively the same job!
    Oh well, the good news is that I start work at another studio on the
    17th October, so I've 2 weeks to sort out all those little things I
    normally ignore, like cleaning the bike more than once a year.
  13. Kevin Seal
    Jim Ingram Guest
    Or use PTFE (plumbers) tape. This will stop any air being drawn in
    and prevent the nipples seizing in the long term.
    Jim
    Jim Ingram, Sep 30, 2005
