braking on ball-bearings
Discussion in 'UK Motorcycles' started by darsy, Nov 18, 2004.
  1. darsy
    well, that's what it feels like.
    on the 7R, no handling problems, no problems with braking at speed, no
    steering funnies at any speed.
    no, what I've got is, when (softly) braking in the last bit between
    5mph and rest, it sometimes - maybe 20% of the time - feels like I'm
    riding over ball-bearings or a series of small ridges on the ground.
    Sort of a notch-ity feeling through the bars.
    What's that going to be then - head race bearings? Brake calipers need
    sorting?
    Yours, clueless of Enfield.
    darsy, Nov 18, 2004
  2. darsy
    flash Guest
    Could be warped disks.
    flash, Nov 18, 2004
  3. darsy
    I've had warped disks before, this feels completely different - a
    really quick series of light judders through the bars.
    darsy, Nov 18, 2004
  4. darsy
    flash Guest
    Is a regular pulsing, cos that would mean the disks. It would also be worth
    checking out your head bearings and examing the road for ball bearings.
    flash, Nov 18, 2004
  5. darsy
    bearings.
    it's not regular pulsing - more like a sort of ratta-tatta-tat random
    notchiness. And it doesn't happen most of the time, which is why I
    don't think it's warped disks.
    And as for examining the road for ball bearings, that was the first
    thing I checked.
    darsy, Nov 18, 2004
  6. darsy
    err, don't think so, but I'll check.
    what, what?
    Sorry, NT, I'll try not to make a habit of it.
    darsy, Nov 18, 2004
  7. darsy
    flash Guest
    Try taking your hands off the bars - but not very far off - when going along
    and see if the bike shakes its head.
    flash, Nov 18, 2004
  8. darsy
    It's an odd one. I too would suspect warped disks, but as you say,
    that ought to show up at higher speeds too.
    I'd try a couple of things - unfortunately, both require the front
    wheel off the ground. Do you have a front paddock stand? If not,
    you'll have to put it on the rear stand and block the front up
    somehow.
    1. Check the headraces for loseness. This would be my first guess as
    to the cause. With the front wheel off the ground, grab the bottom of
    a fork leg with each hand and pull backwards and forwards - can you
    hear/feel any movement? [1] If so, you need to tighten them up
    2. Spin the wheel and check it spins freely without binding. If
    there is a small amount of binding, it may be this only shows up when
    the momentum of the bike is mostly gone. If it binds, or there's any
    untoward noise, take the calipers off and check the pads are ok, and
    that all the pistons are moving.
    Those 6 piston calipers are a bit prone to getting un-balanced, in
    that if dirt/corrosion stops one piston moving properly, the other 5
    carry on, causing un-even pad and disk wear.
    [1] I know you may already know how to do this, but I've typed it out
    in full for the hoards of newbie lurkers out there.
    Champ, Nov 18, 2004
  9. darsy
    Ben Blaney Guest
    Get a man in. (Simian, ideally)
    Ben Blaney, Nov 18, 2004
  10. darsy
    TOG Guest
    Champ has posted how to check for loose head races, down below
    somewhere. To check for notchy ones, just prop the front wheel off the
    deck, and turn the bars with your fingertips, and see if you find a
    notch in the dead central position.
    Really fecked races have more than one notch!
    Other than that - the usual. Tyre wear, presure, and just have a llok
    at the pads to see they're OK.
    TOG, Nov 18, 2004
  11. darsy
    Preston Kemp Guest
    Worn/loose head bearings can do exactly that. When you're braking from
    higher speed or harder, the extra force takes up any slack in the
    bearings & holds it there until the brake pressure is released. When
    you brake at slow speed or gently, the slack is initially taken up, but
    then the weight of the bike pulls it back again. If you're slowing at
    just the right rate, you get the two alternating, leading to that ball
    bearing feeling.
    Preston Kemp, Nov 18, 2004
  12. darsy
    Cane Guest
    Drum & Bass?
    Cane, Nov 18, 2004
  13. darsy
    I only have a rear stand (which the RGV sits on permanently) I'll work
    something out.
    I'll check.
    uh - that looks like something I'd rather pay someone else to do.
    I did, but it's one of the few things I know how to check.
    darsy, Nov 18, 2004
  14. darsy
    Steve P Guest
    Does it make any noise?
    Not that I'm claiming to be an expert or anything but when I bought the
    Gixer the brake seals were knackered and one of the pads used to rattle
    against the disk. Is it possible you might feel this?
    Possibly I'd have thought.
    Steve P, Nov 18, 2004
  15. Champ wrote
    The leading/trailing edge of the holes arriving/leaving the pads?
    I've ridden dozens of bikes but most of them had drum brakes. The
    stopping power of disks is imho such a gift from the heavens that it
    shall not be questioned or examined, merely worshipped.
    I believe you are right.
    steve auvache, Nov 18, 2004
  16. No. Bollocks.
    The Older Gentleman, Nov 18, 2004
  17. darsy
    darsy says...
    Loose brake caliper bolts?
    Lozzo, Nov 18, 2004
  18. darsy
    steve auvache says...
    Tell that to the **** who writes the bike reviews in UMG then.
    Lozzo, Nov 18, 2004
  19. darsy
    Bear says...
    Done exactley the same myself, that's why I suggested it.
    Lozzo, Nov 18, 2004
  20. darsy
    Dan White Guest
    AOL, except it was,
    "OW! WTF just hit my foot?!"
    <grind, grind, crunch, scrape...>
    Side stand down... Get off bike.
    "I say. I seem to have one less brake caliper than would seem to be the norm
    for two front disks".
    <looks down>
    "...and a brake pad embedded in my boot".
    "... and a warranty that runs out in three weeks" :)
    <two days later>
    and a free pair of front discs, calipers, pads and a free service throw in
    by way of "please don't sue us".
    Dan White, Nov 19, 2004
