Breakers/Pattern Parts.
Discussion in 'UK Motorcycles' started by toad_oftoadhall, Sep 11, 2006.
  1. I need some bits for a K1 Bandit 1200.
    Can anyone recommend a BIke Breaker either in the Dorking or Southend
    (or slightly wider) area that might have a K1 B12 in ATM? I want to
    physically go to the place and actually look at the parts before I buy.
    (I've often been offered stuff in breakers that's actually scuffed
    worse than the kit I'm trying to replace)
    Can anyone recommend a decent source of *good quality* pattern Clutch
    levers for the bike.
    Also what other bikes have the same indicators/clutch lever as the K1
    B12?
    What sort of fucked up world is it that lets you put a bike apparently
    securely on the sidestand; walk away; come back and then fall down when
    you're *almost* within catching distance.
  2. toad_oftoadhall
    Rusty says...
    That would be the one good reason not to buy one, aside from the
    Bulldog's other numerous failings.
    Lozzo, Sep 11, 2006
  3. Just buy genuine - I mean, by the time you've farted about trying to
    locate a pattern item of unknown quality, it'll have cost you more than
    the price of a new OE one.
    It's only a lever, FFS.
    The Older Gentleman, Sep 11, 2006
  4. I take your point but it's £35.
    toad_oftoadhall, Sep 12, 2006
  5. toad_oftoadhall
    Chris Cowley Guest
    I agree with TOG - I tried to source pattern parts for my Bandit after I
    damaged the front & rear indicator arms and lenses. Once postage had
    been factored-in they'd have been a few quid *more* expensive then
    genuine parts from a dealer.
    So I bought genuine bits, avoided postage costs, avoided the hassle of
    when/whether they would arrive from an unknown supplier, avoided the
    possibility of stuff being damaged in the post, and ended up saving
    money over buying pattern parts.
    Chris Cowley, Sep 12, 2006
  6. toad_oftoadhall
    DR Guest
    I got one from BanditMania (www.banditmania.co.uk) for under £15,
    IIRC.
    DR, Sep 12, 2006
  7. You forgot: "Avoided the hassle of whether or not the pattern parts
    would actually fit...."
    The Older Gentleman, Sep 12, 2006
