Tomorrow, along with a special pipe, a banjo with a brake switch in it.. Never done brakes on a bike like this before, so i'm thinking change the fluid (whats the best way) cleanup the calipers. Any tips from you nice folks? -- Nige, Land Rover 90 Yamaha R1 Range Rover Vogue
The Gunson's pressure bleeder is my current weapon of choice for changing brake fluid. Much better than the mityvac. More risk of spilling fluid though... The only thing I'd add to the above is if caliper pistons are stuck that holding the free ones in place with G clamps and sturdy tyre levers is my method of choice. If pistons are stuck and don't free up easily, unfortunately what I *think* happens is brake fluid gets behind the seals and then dries out, pushing the seals out and jamming the pistons. Only solution is a complete strip down. Not a difficult job but probably half a day if you've not done it before and things are jammed.
Cheers, i have one of those bleeders like a non return valve, should do the job. I'm quite looking forward to doing it now. Ta -- Nige, Land Rover 90 Yamaha R1 Range Rover Vogue
