Brunstrom is a twat
Discussion in 'UK Motorcycles' started by Steve Firth, Apr 27, 2007.
  1. Steve Firth
    SteveH Guest
    How does this happen?
    I've never even remotely come close to being hit from behind.
    Could it be that you're an over-cautious, hesitant ****?
    SteveH, May 5, 2007
  2. Steve Firth
    Eiron Guest
    That 300kg object (a small grand piano for example) should be dropped
    from a height of 5m to attain a speed of 10m/s.
    How fast does a rifle bullet spin?
    Eiron, May 5, 2007
  3. Steve Firth
    He didn't hitch his roller-shed up properly.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    '02 MV Senna '03 Tigtona 955i '96 Tiger '79 Fantic Hiro 250
    Krusty, May 5, 2007
  4. Steve Firth
    Catman Guest
    http://www.eskimo.com/~jbm/equations/energy.html
    Suzuki Bandit 600
    www.cuore-sportivo.co.uk
    Catman, May 5, 2007
  5. Steve Firth
    Steve Firth Guest
    Yes, now go and learn about the constraints applied to the calculation
    of Kinetic energy. The equation you provide a link to is not valid for
    rotating bodies.
    Steve Firth, May 5, 2007
  6. Steve Firth
    Steve Firth Guest
    It depends on the type of weapon but in the range 140,000 to 250,000
    rpm. The weight given was far too heavy for a typical rifle bullet. A
    7mm bullet weighs about 10g, even a .44 Magnum weighs only 12g.
    An elephant gun fires a 30g bullet.
  7. Steve Firth
    TripleS Guest
    I hope you won't be either, but there's plenty of time yet, Steve.
    That wouldn't justify shunting somebody in the tail. The following
    vehicle would still be primarily at fault.
    Best wishes all,
    Dave.
    TripleS, May 5, 2007
  8. Or the old "4 to the pound"
    Mick Whittingham, May 5, 2007
  9. Steve Firth
    Catman Guest
    Fascinating
    Suzuki Bandit 600
    Catman, May 5, 2007
  10. Steve Firth
    raden Guest
    What, over 4000 revolutions / second?
    I don't think so ...
    raden, May 5, 2007
  11. Steve Firth
    Tunku Guest
    Cover the rev counter too, I use that more than the speedo to judge my
    speed.
    Tunku, May 5, 2007
  12. Surprised me too. But here it is...
    http://yarchive.net/gun/ammo/bullet_spin_rates.html
    About 2/3rds down.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, May 5, 2007
  13. Steve Firth
    Eiron Guest
    No need. Hypocrite Kev Uno-Hoo! has already boasted that he always
    safely exceeds the speed limit. That's a result.
    Eiron, May 5, 2007
  14. Steve Firth
    Steve Firth Guest
    I don't care what you think, the range given is correct. Bullets from a
    hand gun rotate more slowly, about 100,000 rpm.
    And since ICBA going though it all, look here:
    http://en.wikipedia.org/wiki/Twist_rate
  15. Steve Firth
    Steve Firth Guest
    You'd have looked more grown up if you'd admitted you were blagging.
  16. Steve Firth
    Catman Guest
    The same would apply if you'd read the whole thing.
    Suzuki Bandit 600
    Catman, May 5, 2007
  17. If it is traveling at 1000 m/s that is 25cm per revolution, is that a
    problem? Speed at the circumference about 100 m/s, and 1% more KE?
    Nick Finnigan, May 5, 2007
  18. Steve Firth
    raden Guest
    raden, May 5, 2007
  19. Steve Firth
    Steve Firth Guest
    I did. Maybe you should actually have taken 'O' level physics then you'd
    know why you're being a dick.
  20. Steve Firth
    Steve Firth Guest
    Hence why you cannot treat a bullet as a non-rotating system for the
    purpose of calculating KE. Also why bullets "tumble" inside the body.
