Buggerit, so that's what that noise is :-(
Discussion in 'UK Motorcycles' started by Andy Hewitt, Jun 17, 2004.
  1. Andy Hewitt
    Andy Hewitt Guest
    I've been trying to work out what the clonking is on the back suspension
    for a couple of days now. This afternoon I had a good look around, and
    eventually found play in the shock absorber pivot arm.
    Fuckit, that looks like about 3 quids worth of parts and at least half a
    days of work to do.
  2. Andy Hewitt
    mb Guest
    I think them there bearings may cost a bit more than 3 quid...
    mb, Jun 17, 2004
  3. Andy Hewitt
    Martian Guest
    Oooh, pivot linkage bearings and bushes needed there then, prolly some
    seals as well.
    Guess What?
    You CANNOT get them anywhere but the OEM supply.
    Cost me around £90 to do the bandit, however now the shock works properly.
    Martian, Jun 18, 2004
  4. Andy Hewitt
    Andy Hewitt Guest
    About 20 quid from the FJOC.
    Andy Hewitt, Jun 18, 2004
  5. Andy Hewitt
    Andy Hewitt Guest
    No seals on these, just a couple of daft tin shields.
    I can get a set from the FJ Owners club.
  6. Andy Hewitt
    mb Guest
    Bargain.
    Make sure you tell them the right year. I think they may have changed
    those bearings between models 1990 and 1991. I see you have ABS, that
    means a later model.
    mb, Jun 18, 2004
  7. Andy Hewitt
    Martian Guest
    but of course, how else would you prevent water and dirt from getting
    into the bearing?
    I would be interested to know how much of a difference that makes, can
    you let me know?
  8. Andy Hewitt
    Martian Guest
    Ignore the other post then.
    BTW you should do the bushes and pivot pins as well.
    Getting the new bearings in is tricky and requires the use of a drawbolt
    affair, the HBOL will tell you how.
  9. Andy Hewitt
    mb Guest
    mb, Jun 18, 2004
  10. Andy Hewitt
    Andy Hewitt Guest
    Yes, I have the catalogue here, so I know I picked the right ones.
    Cheers.
  11. Andy Hewitt
    Andy Hewitt Guest
    Aye, I think they add another tenner, which in all isn't too bad.
    Righto. I have the Clymer BOL here.
  12. Andy Hewitt
    Andy Hewitt Guest
    Erm, perhaps with something a tiny bit more substantial than what they
    have here.
    Already answered I see (I learn quick I do!).
