Busa down
Discussion in 'UK Motorcycles' started by Gyp, Jul 5, 2010.
  1. Gyp
    Gyp Guest
    Wheeled it out of the garage and then lent it on the side stand.
    Well, I would have done if the stand hadn't folded up at some point on
    the 10-foot journey. It's a sickening feeling as the bike falls away.
    At least the towbar of the Gypmobile wasn't damaged where the bike hit it.
    Gyp, Jul 5, 2010
  2. Gyp
    Oh bugger. Clumsy ****.
    Krusty, Jul 5, 2010
  3. Gyp
    Gyp Guest
    That's just what T said.
    Gyp, Jul 5, 2010
  4. Gyp
    Nige Guest
    Horrible feeling & **** all you can do....
    Nige,
    'Candygram for Mongo'
    R1
    Nige, Jul 5, 2010
  5. Gyp
    Aww, shit.
    I can recall when I dropped my TL in roughly similar circumstances -
    I had pulled it upright and was kneeling beside it to check the oil
    level and it just rolled forward over the garage threshold. The
    sidestand folded and it toppled away from me. Never mind, though, the
    rough brickwork behind the garage door frame caught the tank and broke
    its fall. Sort of.
    Pip Luscher, Jul 5, 2010
  6. Gyp
    Or just buy a set of 4-pots.
    ogden, Jul 5, 2010
  7. Gyp
    I've had an Italian bike for 15 years so I always assume the stand has
    flicked up anyway.
    I've had a few comedy/terrifying moments at the first left hander on
    other bikes, mind.
    sweller, Jul 5, 2010
  8. Gyp
    Beav Guest
    It's even more sickening when the side stand *doesn't* flick up and you try
    wheeling the bike onto a bike lift.
    I was about to start servicing my pal's SV 650 last weekend and he ran it
    onto the lift when my back was turned. The side stand hit the "ramp" and
    tipped the bike away from him and it fell smack bang onto the cylinder head
    of my compressor.
    Thankfully, compressor cylinder heads are tougher than SV fuel tanks. He was
    not a happy chappy, but at least the service went well and the bike's
    running well and very smoothly again.
    By **** can he go through chains and sprox though.
    Beav, Jul 5, 2010
  9. Gyp
    Gyp Guest
    Mine doesn't so I haven't. That said, I rarely walk it out lefthanded so
    I'd normally spot it.
    Damage is scratches or scuffs to:
    Screen
    Upper fairing
    Lower fairing
    Mirror housing
    Mirror extender plate
    Crankcases
    Silencer
    and the new main bracket that I put on about 3 weeks ago is bent and the
    mirror rubber is split
    Could be worse; new main bracket and screen and some touch up should see
    me right
    The latest PB has an article on caliper rebuilds and suggested using a
    brass wheel on a Dremmel to clear the seats for the seals; something I'd
    not seen before.
    Anyway, let me know when you're ordering as I'll probably have a set
    too. If I'm changing the hoses and the pads I might as well do the
    calipers too.
    Gyp, Jul 5, 2010
  10. Gyp
    That's what I did on both Tigs & the SV recently. The 14 year old seals
    in RatTig were fine, no sign of any damage or wear, so I stuck 'em back
    in again. Would've done the same with the SV if it was my bike.
    They were all binding badly beforehand, & perfect after, so I wouldn't
    hesitate to re-use the seals if they look ok.
    Krusty, Jul 5, 2010
  11. Gyp
    did you ever ride my R65LS? The center stand would ground out, making
    the whole shebang vibrate, and this made the side stand fall down, and
    then that'd ground out, and - hey - why's my rear wheel not on the
    ground any more?
    I remember being on a BOTAFOT, overtaking that bloke Sean on his
    CBR600 on a bend, and the whole feeling was that I went around the
    corner mostly on the front wheel with the rear just skipping over the
    tarmac. Great bike. Do you still have it? I still have the V5 (I
    think).
    darsy, Jul 5, 2010
  12. Gyp
    I might agree if seals were sensible money, but they're not, they're
    fucking insane money. If it was something wrong with the seals that
    caused the binding, then yeah, replace them. But im(limited)e it's the
    corrosion in the grooves forcing the seal against the piston that
    causes the problem, & the seals themselves will be fine unless the
    pistons are pitted enough to damage them.
    Krusty, Jul 5, 2010
  13. Gyp
    Emailed
    Lozzo, Jul 5, 2010
  14. Gyp
    Been doing that for years.
    Lozzo, Jul 5, 2010
  15. Gyp
    Give me a feckin' chance to get home, grab a cuppa and catch up on
    stuff!
    Emailed.
    Lozzo, Jul 5, 2010
  16. Gyp
    GungaDan Guest
    I never bothered replacing the dust seals on mine when this happened
    having read on a forum somehwere that you could survive without them.
    Not saying this is a good policy but I had the bike for another 4
    years without any apparent ill effects. Still had to de-stick the
    pistons at least once a year though.
    As an aside, the Hayabusa 6 pots are (hilariously) seen as an upgrade
    for Sprint owners.
    GungaDan, Jul 5, 2010
  17. Gyp
    Gyp Guest
    any recommended local paint toucher-uppers?
    Tim at Motovation recommended a mob in Stroud
    Gyp, Jul 5, 2010
  18. Gyp
    I put a home made 'omega' link in place of the straight link on my
    Guzzi Quota to clear the bolt head that otherwise turns it into a
    suicide-stand. The V11 side stand is a conventional over-centre jobbie
    anyway.
  19. Gyp
    Krusty, Jul 5, 2010
  20. Gyp
    Simon Wilson Guest
    On 05/07/2010 17:59, Gyp wrote:
    Yes I did this on the last set of calipers I rebuilt - admittedly they
    were SO cast iron cage ones though. It worked a treat.
    At the weekend I farted around adjusting the rear (drum) brakes on an
    even Shitier Old car. I had the usual problem of levering the drums off
    'cos there was a lip at the edge. A few seconds with a die grinder and
    they were as good as new - why didn't I think of that before?
    Simon Wilson, Jul 5, 2010
