Cable or Hydraulic Clutch
Discussion in 'Motorcycle Technical Discussion' started by rricciardi, May 22, 2005.
  1. rricciardi
    rricciardi Guest
    Been looking into a transmission for a custom build. Can someone tell
    me if there are any advantages or pitfalls between selecting a cable
    vs. hydraulic clutch setup?
  2. How strong is your grip? Do you have big strong hands? Maybe you could
    squeeze 40 pounds and with a 10:1 clutch lever ratio, you might be able
    to throw out a mechanical clutch with 400 pounds of force...
    What is the spring rate of your clutch springs, and how many are there,
    and how much preload is on them? An engineer would need to know all
    that to select a cable system or a hydraulic system...
    Hydraulic clutches have better pressure ratios, that's why they are
    used on a lot of motorbikes...
    Suppose you have a 5/8th inch diameter master cylinder piston and a
    2-inch diameter slave cylinder. The 5/8th inch diameter piston has an
    area of 0.307 inches. The slave cylinder piston has an area of 3.14
    inches...
    3.14 divided by 0.307 = 10.2
    So, if you can push on the master cylinder with 40 pounds of force, you
    can get 400 pounds of force at the clutch throwout bearing...
    The slave cylinder piston only moves 1/10th the distance the master
    cylinder piston moves, but has ten times as much force as you applied
    at the piston...
    And, your clutch lever has leverage over the piston too, so the actual
    effort it takes for your hand to squeeze the clutch lever is going to
    be a lot less than what it would take to squeeze the lever of a cable
    system...
    krusty kritter, May 22, 2005
  3. rricciardi
    mike Guest
    It's not a motorcycle, but I have a 1990 Nissan Pickup with a hydraulic
    clutch.
    The ONLY thing that's ever failed on this truck is the clutch slave
    cylinder.
    mike
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    Wanted, PCMCIA SCSI Card for HP m820 CDRW.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
    Wanted 12" LCD for Compaq Armada 7770MT.
    Bunch of stuff For Sale and Wanted at the link below.
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
    mike, May 22, 2005
  4. Hydraulic clutches were opriginally supposed to be lighter to operate.
    Ho ho ho.
    Some people like saying that hydraulic clutches are the only way to deal
    with power outputs of 100bhp and over. This is pure crap.
    A lot depends on the way the thing is designed. Kawasaki's fuel-injected
    Z1300, introduced in about 1984, developed 130bhp and had a cable
    clutch, whose actuation (at the lever end) was changed from the earlier
    carb model.
    If you ever get the chance, look at the handlebar lever, the fulcrum
    point, the cable attachment point, and marvel - as I did - at such a
    simple and elegant engineering solution.
    I don't know any modern hyperbike (say 140bhp-plus) that has a cable
    clutch, mind you - but the Z1300 example shows that it may not be
    strictly necessary.
    My Ducati (see sig) produces about 60bhp, and has a hydraulic clutch
    designed for someone who delights in squeezing tennis balls in his fist
    for recreation.
    The Older Gentleman, May 22, 2005
  5. rricciardi
    The Family Guest
    Looking at your sig, you should know that the Rocket3 is supposedly
    140hp-plus, and has a cable clutch - unfortunately.
    Actually, I would think the torque output would be a more important
    measure than horsepower. Personally, I prefer a hydraulic clutch for
    the low maintenance, without regard to the pull.
    Gary
    The Family, May 22, 2005
  6. I have a 20 year old Nissan PU, with nearly 157K miles on it, and I've
    been wondering when the slave cylinder is going to give out...
    (The first car I ever had with a hydraulic clutch system was a 1957
    Jaguar.
    It was very difficult to get the transmission to go into first gear
    when stopped because it had straight cut gears in first and reverse.
    Second, third and fourth were synchromesh. I suspected that I could
    help the gear grinding problem by making the clutch release better, so
    I rebuilt the slave cylinder and bought a new master cylinder, and
    changed the carbon throw out bearing but, it was no use, first gear
    continued to grind, it was a feature of that transmission. Wizard
    drivers could actually shift into first gear while rolling, but I was
    no wizard...)
  7. Thanks for that - I honestly didn't know that.
    Yes, I think you're probably right.
    There is that, but to be honest, the amount of maintenance a cable
    clutch needs is minimal - a very occasional twiddle on the adjuster, and
    that's it.
  8. When you do have to work on the hydraulic system, bleeding all the air
    out of the system takes longer than just changing a worn out clutch
    cable would take...
    The amount of effort required to pull some hydraulic clutch levers in
    can sneak up on you...
    After riding all day on my GSXR and constantly shifting gears using the
    hydraulic clutch, my forearm will become sore, and I start shifting up
    without clutching...
    The hydraulic clutch on my FZR lacks any feel whatever for when it's
    going to engage as I release the lever. Combined with the light
    flywheel effect, it's difficult to judge when the machine is going to
    start moving from a stop. It's mostly a parking lot and start out
    problem that vanishes on the open road...
    I complained about this lack of lever feel to a friend who has a cable
    release set up from the factory race kit on his FZR. His cable release
    system has no more feel than my hydraulic system. The lever has a
    totally dead feel to it...
  9. rricciardi
    The Family Guest
    That's probably right. But, it's been so long since I had a cable clutch,
    I can only remember occasional breakage at the most inopportune
    times.
    Thanks,
    Gary
  10. Sure. Here are a few:
    A cable won't seep out of a weepy fitting and leave you stranded.
    Hydraulics won't fray on the end and break, launching you into traffic at a
    stoplight.
    You can usually find replacement bits for cable operated clutches at most
    independent bike shops and often at HD dealers. That's less often true of
    hydraulics, but hydraulics are more resistant to wear so it's less of an
    issue.
    With hydraulics you can easily figure out your master/slave ratio to change
    the force necessary to operate the clutch.
    Cable operated clutches have more feel than hydraulics. Or perhaps it's that
    they have a different feel. With a cable clutch you can feel the engagement
    point of the clutch in your hand (or foot, in my case). You can't with a
    hydraulic clutch. At least I can't. With a hydraulic clutch I have to feel
    the engagement point by sensing when the bike is just starting to move.
    If you want to worst of both worlds, you could set up a hydraulic clutch with
    a remote, cable operated master cylinder.
    Regarding the slave cylinder, since you're posting this to a harley group, I
    assume you're building some sort of harley clone. All of the hydraulic
    clutches I'm aware of for these trannys incorporate the slave cylinder
    directly into the end cover of the transmission.
    While shopping these, make certain that there is a reasonable way to check
    and add tranny fluid. I picked up one cheap from eBay ( a Ness thing) that
    works fine, but there's no dip stick to check the tranny oil, no sight window
    to check the oil level,and the only way to add oil is through a tiny little
    fucking 3/8" bolt hole on top of the cover. Ever try to replace you tranny
    oil through a 3/8" hole? Sooner or later I'm gonna meet Arlen Ness and I"m
    going to bitch slap the son of a bitch for being so goddamned
    form-over-function.
    Spunky the Tuna, May 22, 2005
  11. rricciardi
    Sparkle Guest
    Cables stretch, pieces wear... it's insidious.
    Hydraulic always maintains the same feel. The fluid reservoir
    compensates for any slack that would otherwise be felt at the clutch lever.
    The other replies about pressure ratios, torque, etc. are nonsense.
    Sparkle, May 23, 2005
  12. Go find a master cylinder and slave cylinder with the same piston
    diameters and report back here when you do...
    krusty kritter, May 24, 2005
  13. rricciardi
    Sparkle Guest
    Your answer to the question of cable vs. hydraulic was
    "Hydraulic clutches have better pressure ratios, that's why they are
    used on a lot of motorbikes..."
    You clearly seem to think that cable systems have simple 1:1 ratios,
    with no force multiplication. So go find one, and report back.
    Sparkle, May 24, 2005
  14. Consider yourself lucky that it wasn't the brake m/cylinder that decided
    to have an off day =:0
    The Older Gentleman, May 24, 2005
  15. No, I never said that I thought any such thing. Obviously a clutch
    lever is a clutch *lever*, and there is force multiplication at the
    cable end of the lever...
    But a hydraulic system has two kinds of force multiplication, pure
    lever and the pressure ratios of the two systems...
    You might see master cylinders and slave cylinders with approximately
    the same diameters in foot-operated systems, like a car's hydraulic
    clutch throwout system, but motorbikes are going to have to have a
    small master cylinder diameter and a large slave cylinder diameter to
    multiply force, or the rider needs forearms like a gorilla to squeeze
    the lever and the similar piston diameter hydraulic system becomes
    nothing but a fluid cable that never needs adjusting...
  16. Nicely put. Succinct, clear, and accurate.
    I can tell you don't do technical writing for a living. Your description is
    much too clear.
    Spunky the Tuna, May 24, 2005
  17. rricciardi
    James Clark Guest
    But you ignore that there may be additional mechanical advantage applied at either end of the cable.
    For Harleys, various ball-and-ramp assemblies and modifications are available to adjust clutch pull
    to the rider's preference.
    If the clutch throw-out is operated by an external lever, a sliding extension would allow you to
    tailor the clutch pull to get the lightest pull while still getting enough travel for full
    disengagement. With hydraulic, you're stuck with one MA unless you choose to replace one of the
    cylinders. Aside from the expense, fine tuning of bore diameters would be limited by the
    availability of seals of the desired diameter.
    I still prefer hydraulic as they are self-adjusting and eliminate the need to make compromises in
    cable routing. If the original cable of my FLHRCi fails in the *next* 110,000 miles, I'll probably
    switch to hydraulic.
    James Clark, May 24, 2005
  18. rricciardi
    Sparkle Guest
    Think that was clear? What does "the pressure ratios of the two systems"
    mean?
    First, krusty wants us to believe that two *kinds* of force
    multiplication are somehow stronger than two multiplications of the same
    kind. Nonsense!
    And then, as James Clark noted, krusty just ignores leverage at the
    other end of the cable anyway! That leverage is analogous to the slave
    cylinder. Why did krusty forget it?
  19. <snip>
    I'll take his advice over yours. Sorry, old chap.
  20. How kind of you, sir...
    The original poster cross posted his enquiry to rec.motorcycles.harley
    and rec.motorcycles.tech and never responded to any message of advice.
    Somebody else crossposted the message to rec.motorcycles...
    Now the thread will live forever, it may grow to hundreds of messages
    in length as the trolls and flamers and users who are weeks behind in
    their important task of monitoring all their Usenet NG's...
