Calling diesel heads
Discussion in 'UK Motorcycles' started by rufty_tufty_hoolythug, Aug 5, 2009.
  1. My wife has an Hyundai Accent 1.5 Diesel 2002 model. Shortly after
    buying it, it would not start for me when I left work. I cranked it 4
    or 5 times and got nothing. I went back into my office, left it ten
    minutes, went back out and it started as if nothing had happened.
    That was quite a few weeks ago. Yesterday my wife was out in the car
    and on leaving the local Tesco it would not rev. The throtte pedal
    did nothing. She called the RAC who came out and basically fiddled
    about and the car start revving again and carried on as if nothing had
    happened. The RAC man said that he had hadn't actually done anyting
    to get it going again.
    Does anyone have any ideas as to what's going on? While on the
    subject, what's the best way to change a diesel fuel filter? I've
    heard bad things about disturbing a diesel's fuel supply and setting
    up airlocks which I think changing the fuel filter is kind of going to
    do.
  2. rufty_tufty_hoolythug
    http://en.wikipedia.org/wiki/Crankshaft_position_sensor
    platypus, Aug 5, 2009
  3. rufty_tufty_hoolythug
    DozynSleepy Guest
    Kwik fit or it's equivalent. You can't buy the filter and oil cheaper
    than you pay them to change it and dispose of the waste.
    I'm sure I got a voucher for £5 off a oil and filter change from
    National posted through the door the other day which will make it even
    cheaper.
    DozynSleepy, Aug 5, 2009
  4. rufty_tufty_hoolythug
    Adrian Guest
    How much do Krap-**** charge?
    For my Saab, I just got a couple of genuine oil filters for less than £3
    each, and a sump washer about 50p.
    I bought 20 litres of full synch Fuchs oil from Opie Oils for £62 - just
    over £3/litre. So an oil change - with a known brand and grade of top
    quality oil - gives change from £20, and you've got plenty for top-ups
    and future changes, so don't have to pay Halfrauds or petrol station rip-
    off prices for a litre bottle. It's free to get shot of the old oil and
    filter down at the local tip.
    And - even better - I don't get a big long list of non-existant faults
    and high-pressure selling that it's "dangerous" to take it out of there
    without having them fixed.
    Adrian, Aug 5, 2009
  5. rufty_tufty_hoolythug
    Twat.
    ogden, Aug 5, 2009
  6. rufty_tufty_hoolythug
    TOG@Toil Guest
    What he said. Mind you, for a high-performance diesel[1] I'd want to
    know what oil they're putting in it. My Scoob, for instance, uses some
    very special fully synthetic lube. I had a 6k miles interim oil and
    filter change[2] done last week by the supplying dealer.
    [1] ie: probably not a Hyundai.
    [2] "Oil is cheap[3] and engines are expensive".
    [3] £68 was the bill. I didn't think that was bad at all for a couple
    of gallons of 'proper' oil, filter and labour.
    TOG@Toil, Aug 5, 2009
  7. rufty_tufty_hoolythug
    TOG@Toil Guest
  8. rufty_tufty_hoolythug
    Adrian Guest
    I know they are. But how much do they charge?
    Adrian, Aug 5, 2009
  9. rufty_tufty_hoolythug
    stick your reg no in this and see if they match the spec
    http://www.national.co.uk/order_oil.asp
    They recommend Castrol Magnatec 10W/40 for my car, which meets the handbook
    spec.
    wessie, Aug 5, 2009
  10. rufty_tufty_hoolythug
    TOG@Toil Guest
    "The oil required for your vehicle is not currently available from
    this web site, please refer to your vehicle owner's manual." Heh. Said
    it was very special. Useful little link that is, all the same.
  11. rufty_tufty_hoolythug
    Naah, it says that if I put the old Volvo's reg in, and that
    definitely had a Castrol product recommended. I think its just that
    their reg look-up isn't very good and can't always get the correct
    vehicle details. (A made-up plate gives a different message).
    Ace, Aug 5, 2009
  12. rufty_tufty_hoolythug
    higgins@work Guest
    He was talking about the in-line fuel filter, do Kwikfit change those?
    higgins@work, Aug 5, 2009
  13. rufty_tufty_hoolythug
    higgins@work Guest
    I tend to use the latter as I think they tend to be hugely over-priced
    compared to a good motor factor.
    I'm not really sure that helps his case much.
  14. rufty_tufty_hoolythug
    DozynSleepy Guest
    D'oh !
    Heh, well spotted. They only change the fuel filter if you put it in for
    the full service at £139, so a DIY job for a couple of quid is the way
    to go on that.
    I should have spotted that, I've just disposed of 160 litres of fuel in
    the form of waste veg oil that I'd had lying around since getting rid of
    the Pajero.
  15. rufty_tufty_hoolythug
    TOG@Toil Guest
    Too right. Bulbs from Halfords: individually blister packed, sometimes
    in pairs, and twice the price they cost from the Tunbridge Wells old-
    fashioned[1] accessory shop, where they just open a drawer, rummage,
    pull out a cardboard box, and hand them over.
    [1] Imagine the 'Four Candles' sketch set in a motor factor, and
    you'll have it perfectly pictured.
  16. rufty_tufty_hoolythug
    Adrian Guest
    <awaits attempted defence of K-F>
    Adrian, Aug 5, 2009
  17. rufty_tufty_hoolythug
    JB Guest
    <tumbleweed......>
    JB
    JB, Aug 5, 2009
  18. Grimly Curmudgeon, Aug 5, 2009
