Calling the Tyre Pluggers!
Discussion in 'UK Motorcycles' started by Mark, Nov 4, 2007.
  1. Mark
    Mark Guest
    Was it WUN that recently posted about getting a Z rated tyre repaired?
    Anyway, i've got another rear puncture and can't find a local shop that will
    plug it due to British Standard BS159F (1).
    It's only got about 1k of life left so it probably is worth replacing
    anyway. Especially with the 400 mile trip to the show and back coming up.
    (1) No repairs allowed in any Z rated tyre.
    Mark
    Mark, Nov 4, 2007
  2. Mark
    Have you actually looked this up?
    _______
    ..'_/_|_\_'. Ace (bdotrogers a.t compaqnet.fr)
    Ace, Nov 4, 2007
  3. Mark
    I have, and while I can't find the exact text of the standard itself
    (short of handing over £102 to BSI for a pdf) every single reference
    I've found says that it only permits repairs to tyres up to V rating.
    Any beyond that (eg. W, Z) cannot be repaired under the auspices of
    BS159F:1997.
    However, BS159F is only a standard, not a legal requirement. It's
    certainly not illegal to plug a Z rated tyre, but I wouldn't be
    surprised if some fitters declined to do so under the terms of their
    public liability insurance.
    That said, I've had Z rated tyres plugged in the past with no problems.
    It's just a matter of finding a fitter who'll do it (Universal in
    Staines certainly did, but probably not much use to the OP.)
    ogden, Nov 4, 2007
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Mark
    Yes it was. The repair cost forty quid mind, so for 1000 miles left in
    the tyre it's probably not worth it.
    Honda GL1000K2 (Fallen apart) Suzuki TS250 "The Africa Single"
    Norton 850 Commando Kawasaki GTR1400
    Wicked Uncle Nigel, Nov 4, 2007
  5. Mark
    Mark Guest
    Basically the same findings from me. Not illegal to plug as no mention of
    punctures made in construction and use regs. However, law would probably
    favour BS approach for reasonableness if involved in an accident. Problem is
    i've never heard of a failure in a plugged tyre and even if it did I would
    think it would be just like getting another puncture.
    Seems to me in these days of litigation for everything the decision by
    companies is led by the fear of being sued rather than whether a plug would
    actually work fine in a Z rated tyre (just I think it would).
    Mark
    Mark, Nov 4, 2007
  6. Mark
    Mark Guest
    Factor in that I had ridden it for 20 miles dashing between garages to keep
    it inflated may also mean that I've damaged the internals. On looking at it
    when I got home it looked like it had just finished a track day and was
    pretty warm.
    That's another £100 then.............
    Mark
    Mark, Nov 4, 2007
  7. Mark
    Mark Guest
    Although I can't find the actual BS wording an awful lot of info online
    suggests the same. Anyway, the detail is rather academic really as I can't
    find a dealer that will plug the tyre.
    Mark
    Mark, Nov 4, 2007
  8. Mark pretended :
    I seem to remember having seen DIY tyre plugging kits quite recently.
    Harry Bloomfield, Nov 4, 2007
  9. Mark
    Tosspot Guest
    40 squids is bloody cheap, and in the realms of old Tossies mind, cheap
    things are things you can do yourself. So, has anyone tried plugging
    their own? Kit cost? Training?
    Actually, just having googled it, the kits seem to be about 20 squids,
    so anyone tried?
    Tosspot, Nov 4, 2007
  10. Mark
    Beav Guest
    Plugs have never failed on any tyre I've plugged and that included Z rated.
    Two (one BT-014 and one Conti Sport Attack) within the first 300 or so miles
    of fitting them. That's using a "home repair" kit too and not backed up with
    a tyre shop repair later.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 4, 2007
  11. Mark
    Mark Guest
    I tried taking the tyre off the rim without any equipment and it wouldn't
    budge so the DIY approach would have to involve buying some equipment or a
    real bodged approach.
    Don't really fancy that on a 170 mph bike that tends to see three figures on
    most outings.
    Mark
    Mark, Nov 4, 2007
  12. Mark wrote :
    You plug them from the outside with the tyre still on the wheel I
    think. The old kits used a rubber bead, solution and an pointy hooked
    implement. Fit the bead into the implement, dip it in the solution,
    force it into the hole and cut off.
  13. Correct. But I tried using one on my K the other day, and the bloody
    plug tore to shreds every time I tried to force it through the hole, so
    I wound up taking the wheel down to the tyre shop.
    They used a plug, which they fitted from the inside, which obviously
    meant taking the tyre off the rim. They said that for a pro (as opposed
    to DIY) repair, this was now the law.
    Cost £15 anyway, which wasn't bad. And thank Ged for BMW Monolever rear
    wheels which are as quick and easy as a car wheel to remove, if not more
    so.
    The Older Gentleman, Nov 4, 2007
  14. See other posting.
  15. Why shouldn't it work? That's the question. Surely the Z rating just
    means the tyre is rated as safe at higher speeds, therefore as long as
    you don't do Z speeds, it's just the same as a lesser tyre.
    Paul.
    CBR1100XX SuperBlackbird (Buen mueble de patio)
    And a pushbike of some sort.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
    http://obscuredomainname.org
    Paul Carmichael, Nov 4, 2007
  16. Paul Carmichael formulated the question :
    The tyre has to have a speed rating to match the vehicles maximum speed
    capability, irrespective of a countries overall maximum limit. Any
    repair has to be also suited to that same maximum speed of the vehicle.
  17. Yes, years ago mind. Confucian approach and everything. Fucking shit
    wouldn't do it a third time.
    Eh?
    steve auvache, Nov 4, 2007
  18. Mark explained on 04/11/2007 :
    http://www.bykebitz.co.uk/acatalog/Tyre_Products.html
    £7.99 inc VAT - Inc. delivery £11.99
  19. Mark
    Where are you? If we knew that we might be able to recommend somewhere.
    wessie, Nov 4, 2007
  20. Yebbut you don't have to actually *do* the maximum speed of the
    vehicle. If a repair is ok for up to certain speeds, then what
    difference does it make what the tyre rating is?
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
