Can I just say....
Discussion in 'UK Motorcycles' started by The Older Gentleman, Oct 29, 2006.
  1. ....that replacing steering head bearings is about my least favourite
    motorcycling maintenance job?
    Thanks.
    DT50MX done: Z650 next.
  2. The Older Gentleman
    On Sun, 29 Oct 2006 18:39:52 +0000,
    I had to change front wheel bearings in the 9R yesterday but they're
    easy compared to the hassle of doing steering head bearings.
    Andy Bonwick, Oct 29, 2006
  3. The Older Gentleman
    Steve Parry Guest
    Swing arm and suspension linkage bearings are my least fave. Don't mind the
    head bearings to be honest.
    Steve Parry, Oct 29, 2006
  4. The Older Gentleman
    Nah. Engine removal. Fucking heavy, they are.
    ogden, Oct 29, 2006
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, ogden
    <Looks at engine hoist>
    <Frowns>
    Sorry matey, I'm not really following you on this.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Oct 29, 2006
  6. The Older Gentleman
    deadmail Guest
    *gloom* K1100LT felt a bit 'notchy'. I've been trying to pretend it's
    worn tyres but know it's not.
    I think this is going to be a mother-fucker of a job. Still it can
    wait; I think that the K1100 will only get another day or two's use
    before it's put away for the winter.
    deadmail, Oct 29, 2006
  7. The Older Gentleman
    Steve Parry Guest
    http://www.ibmwr.org/ktech/steer-bearing-rem.shtml
  8. The Older Gentleman
    Steve Parry Guest
    PS I did the head bearings on the 650 a short while ago, and while I had the
    fork legs off popped some gaiters on them.
  9. The Older Gentleman
    deadmail Guest
  10. I checked the races on mine - they're fine. For something as big as this
    sort of job, I'll GAMI. I simply can't be arsed to DIY.
  11. The Older Gentleman
    Looks like I may be doing a bit of engine removal soonish. These "engine
    hoist" things: good, are they?
    platypus, Oct 29, 2006
  12. The Older Gentleman
    Eddie Guest
    Did mine a few weeks ago, and considering it was the first time I'd done
    wheel bearings, it wasn't that bad. Certainly be easy enough next time.
    I reckon brake caliper seals are the worst job.
    Oh, and guess what I need to do...
    Eddie, Oct 29, 2006
  13. The Older Gentleman
    Statto Guest
    Black Behemoth still playing up?
    Statto, Oct 29, 2006
  14. The Older Gentleman
    Sigh.
    The reg/rec seemed knacked, so that's been replaced, and I was seeing
    voltage from the alternator. But there's no extra volts showing up at the
    lead/acid end of the business.
    Closer inspection shows that the actual AC voltage across the alternator
    phases is 20-5-5. Ish.
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    I wouldn't be without mine. TBH, they're a bit OTT for most bike
    engines[1] but they don't half make it easier. "Up half a gnat's tadger.
    Right, let's stop and have a good look round. Looks OK, up a shade more.
    Hold it there. Oh, right drop it a tiny bit. Hold it... OK. I think
    that's OK. Left a bit. Now back up bit. Blimey, Eric's gone a very
    strange colour!"
    Much betterer with hydraulics.
    [1] Unless you're talking about something bizarre like a GlodWing...
  16. The Older Gentleman
    Eddie Guest
    I think it's because previously I've always been reluctant to split the
    caliper, which makes it a right PITA to get at the things. These days
    I'm much happier to take almost anything to pieces.
    I've just thought of something worse: anything on the GSX600F.
    Eddie, Oct 29, 2006
  17. The Older Gentleman
    deadmail Guest
    I'd agree. 'specially if you've got a vacuum bleeder.
    I can; anything that needs the clutch bellhousing removed from a BMW K
    series bike. Probably not so bad when they were new, but 20 years on
    there will be multiple, fucked fastners to overcome. It's a full
    weekend job. Especially fucking shitty if they have the ABS system
    fitted.
  18. The Older Gentleman
    Bizarre?
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Well, we both own one and Dodger is similarly afflicted. I'd like a
    Robbo to be taken into consideration too.
    The prosecution rests, m'lud.
  20. The Older Gentleman
    Bugger, you're right. <gloom>
    Well, never mind. I should be able to manage with the trolley jack, anyway.
    platypus, Oct 30, 2006
