carb advice
Discussion in 'UK Motorcycles' started by Adam Gamsa, Apr 18, 2007.
  1. Adam Gamsa
    Adam Gamsa Guest
    Hi all,
    My bike starts nicely with the choke. After about 2mins running, the
    revs fall and it stalls.
    If you ride the bike with choke for a couple of minutes, then turn the
    choke off, the bike idles happily.
    Any ideas what's going on?
    Do I just need to adjust idle speed and pilot jets with the engine warm?
    It's a Kwak GPz305 (twin cylinder air cooled 2-stroke)
    Thanks for your help,
    Adam
  2. STAY AWAY FROM THE PILOT JETS
    Nice bike, I commuted one for 3 years, although I had the 4 stroke
    version. During all that time it simply would not run at all well for
    the first two minutes unless on full choke.
    Word of advice, change the belt immediately you find a nick as it will
    break shortly after.
    steve auvache, Apr 18, 2007
  3. Adam Gamsa
    Monz Guest
    <sniffs bait>
    <swims off>
    Monz, Apr 18, 2007
  4. There's your problem right there. Two of the strokes have fallen off.
    You will have to retrace your last journey, looking in the ditches and
    hedges in case they bounced when they hit the road.
    Grimly Curmudgeon, Apr 18, 2007
  5. Adam Gamsa
    MikeH Guest
    "Come behind this hedge and we'll look for your strokes together, sonny"
    MikeH, Apr 18, 2007
  6. Adam Gamsa
    Choke still out or what?
    Whell, I don't know much that particular bike, but it sounds quite
    reasonable to me. Riding it, in traffic at least, will generally warm
    it up faster than just idling it.
    Yes, never play with the mixture unless it's /fully/ warmed up. Two
    minutes' idling isn't 'fully warm'.
    But...
    If it idles fine when warm then it's probably OK; don't mess with the
    jets. If starting from cold or from hot is hard *then* look at the
    low-speed jets and the [choke | mixture enricher].
    ITYM 4-stroke.
    Pip Luscher, Apr 18, 2007
  7. Adam Gamsa
    Adam Gamsa Guest
    Oh dear what a muppet. Of course I meant 4-stroke.
