Carb. Icing
Discussion in 'UK Motorcycles' started by SteveH, Feb 28, 2009.
  1. SteveH
    SteveH Guest
    That's the 2nd week in a row I've taken the Ducati out for an early blat
    on a Saturday morning.
    It's the 2nd week it has largely been a pig to ride due to carb. icing.
    Is there a simple solution for this?
  2. SteveH
    ginge Guest
    Only ride it in summer.
    ginge, Feb 28, 2009
  3. SteveH
    SteveH Guest
    But I wanted to ride this month, not wait for the roads to be stuffed
    full of weekend drivers, just because it's a bit warmer out there.
  4. SteveH
    Eiron Guest
    More throttle.
    Eiron, Feb 28, 2009
  5. SteveH
    SteveH Guest
    Bloody thing keeps bogging down when getting back on the power, then
    spitting and popping as the excess fuel hits the hot exhaust.
  6. SteveH
    Silkolene pro fst.
    Muck, Feb 28, 2009
  7. It *should* have an anti-icing kit which is a set of oil lines, running
    to the carbs. There's a junction box and a tap, like an old Italian fuel
    tap on a 1970s Guzzi, on the junction box. This is so you can turn off
    the heated flow if you want.
    I've never found it necessary to turn it off - I suppose in an Italian
    heatwave you might. But it's possible someone's turned it off on yours.
    The Older Gentleman, Feb 28, 2009
  8. SteveH
    SteveH Guest
    I shall investigate later, as I am swapping a fairing panel - managed to
    get a replacement for the one I scraped on the BOTAFOT last summer for
    less money than having mine painted.
  9. SteveH
    Catman Guest
    My Duke used to have the same issue. I found that Super petrol helped.
    Didn't eliminate it, but made a pretty good job.
    www.cuore-sportivo.co.uk
    Catman, Feb 28, 2009
  10. SteveH
    Silkolene pro fst.
    Muck, Feb 28, 2009
  11. SteveH
    bod43 Guest
    Fuel injection.
    bod43, Feb 28, 2009
  12. SteveH
    Can you buy that in a bottle at Halfords?
    Muck, Feb 28, 2009
  13. SteveH
    Catman Guest
    So I heard. I went for the FI option.
  14. SteveH
    Catman Guest
    Not round here, they weren't. Lovely it was.
  15. SteveH
    Quite... bit of an expensive retro fit though.
    Muck, Feb 28, 2009
  16. SteveH
    Catman Guest
    Yeah, but the fringe benefits were pretty good. Lots more BHP, blacker,
    got an extra cylinder into the deal as well.
    Catman, Mar 1, 2009
