Carburator "needle" torn
Discussion in 'Motorcycle Technical Discussion' started by NewBie, Nov 25, 2005.
  1. NewBie
    NewBie Guest
    My motorbike was jerking when I traveled half way at the middle of the
    highway. Fuel did not seem to flow smoothly and continously when throttle is
    opened while traveling but I managed to drag to a nearby workshop.
    The technician has checked that the "needle" in the carburator was torn.
    Out of curiousity, what can be the reasons that cause the needle torn?
    Thanks in advance.
  2. NewBie
    NewBie Guest
    Before this happened, I was asked to fill up 4 small holes at the exhaust by
    the inspector from the inspection center.
    Could this be the problem that casued the carburator needle to break?
    Note:
    Face the rear of the motorbike directly, the exhuast hole is at the center
    of the exhuast pipe and 4 small holes besides this center hole.
    Bike Brand: Suzuki Maruader
    Bike model: GZ125
  3. Needles don't tear. Diaphragms do, but that wouldn't provide the
    symptoms you describe.
    My suggestion - a useless mechanic is trying to bullshit you.
    The Older Gentleman, Nov 25, 2005
  4. NewBie
    Pale Fire Guest
    There are TWO things in a carburetor that are called a "needle".
    The jet needle is a long round piece of aluminum that is tapered. It's
    about 50 millimeters long and 3 millimeters in diameter.
    It goes up and down in the brass tube which is called a "needle jet".
    Engine vibration will cause the jet needle to hit the needle jet and
    the jet needle can become worn in the area where it hits the needle
    jet.
    The needle jet will become worn to an oval shape. The jet needle/needle
    jet combination will not work properly when the parts are worn out, the
    engine will get too much fuel at small throttle openings.
    The OTHER part that is sometimes called a "needle" is the float valve.
    It is in the float bowl and it is about 10 millimeters long and is
    square or triangular shaped to guide it up and down in the brass float
    valve seat.
    The float valve has a conical rubber seal on the end to stop fuel
    flowing into the float bowl when the fuel level is high. That rubber
    seal can stick to the float valve seat and the rubber can tear. This
    can happen if the motorbike isn't ridden very often and all the fuel is
    allowed to evaporate out of the float bowl.
    Pale Fire, Nov 25, 2005
  5. NewBie
    Pale Fire Guest
    Bureaucrats will walk all over you, if you let them.
    The four small holes are probably for style. Do any exhaust fumes
    actually come out of those four holes?
    Some rider like more noise from their exhaust system. They drill extra
    holes in the end of the muffler. But it's easy to see that somebody
    drilled extra holes. The extra holes look crudely drilled.
    You should have contacted the inspector's supervisor and told him that
    your muffler is stock and the holes were for styling purposes, and that
    you did not drill any holes in your stock muffler to make more noise.
    If the inspector's supervisor didn't correct his subordinate, you
    should have contacted the supervisor's supervisor. You have to fight
    the bureaucrats or they will walk all over you.
  6. NewBie
    NewBie Guest
    The technician also told me that the "head" (made of rubber) which the
    needle is inside that moving up and down was harden. He replaced the harden
    "head" and now the bike is back to normal.
    There is one set back now that the bike can't go faster than 70km/hr.
    Previously (before this problem) it can go up to 90km/hr.
    NewBie, Dec 1, 2005
  7. NewBie
    CK Guest
    I am still not sure what part was replaced, but it sounds like the
    large rubber diaphragm
    is what he called a "head". If you look at the carburetor parts
    diagrams you won't find anything that is called a "head" in English.
    Maybe that's because the inspector made you weld up some of the holes
    in your muffler. The engine can't breathe in fresh mixture if it cannot
    get rid of the exhaust!
    CK, Dec 1, 2005
  8. My guess is
    You have what's know as a "constant velocity" carburetor.
    The rubber diaphragm holding a slide an needle was torn.
    When he replaced the diaphragm, he may not have gotten
    the needle set right.
    You should probably find another mechanic.
    If you had to fill in holes in the muffler, you may need a new
    muffler.
    Anybody with this many strange problems is likely a troll.
    Rob Kleinschmidt, Dec 1, 2005
  9. NewBie
    CK Guest
    I don't think so. I suspect he's just not very mechanical, compared to
    us. He's apparently in Singapore (or Malaysia, posting to a NG via a
    host with a .edu suffix, so he may be a student whose native language
    isn't English. Maybe "NewBie" <> speaks Cantonese or
    Mandarin.
    CK, Dec 1, 2005
