Cat Spanking
Discussion in 'UK Motorcycles' started by antonye, Feb 15, 2007.
  1. antonye
    antonye Guest
    WTF?!
  2. antonye
    antonye says...
    You were looking for monkey spanking tips when you found that, weren't
    you?
    Lozzo
    Suzuki Bandit 600S (Green with added shit bits)
    Yamaha SR250 Delusion (It's "Special")
    I'm a modern man, I don't mind buying tampons, but apparently they're
    not a proper Valentine's present
    Lozzo, Feb 15, 2007
  3. antonye
    antonye Guest
  4. antonye
    antonye says...
    PANIC!
    Lozzo
    Lozzo, Feb 15, 2007
  5. antonye
    Veggie Dave Guest
    Veggie Dave, Feb 15, 2007
  6. antonye
    That is one kinky cat.
    Pip Luscher, Feb 15, 2007
  7. antonye
    Cab Guest
    Cab, Feb 15, 2007
  8. antonye
    TOG Guest
    This is just weird.
    It would be even funnier if he dressed the cat up in a little gimp
    suit.
    TOG, Feb 15, 2007
  9. antonye
    antonye Guest
    Click on the "more videos from this user" thingy
    next to the video and there's another crazy one
    in there too.
  10. I'm wondering if both cats are male. All the male cats who've owned me have
    reacted very strongly to stimuli around the base of the tail and flanks.
    Ali
    Alison Hopkins, Feb 15, 2007
  11. antonye
    It's not restricted to males, although it's perhaps more marked than
    in females.
    _______
    Ace, Feb 15, 2007
  12. antonye
    Beav Guest
    Here come de judge.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 15, 2007
  13. antonye
    muddy cat Guest
    muddy cat, Feb 15, 2007
  14. antonye
    "remember Agincourt"
    darsy, Feb 15, 2007
  15. antonye
    muddy cat Guest
    We few, we happy few... Sorry. I was actually thinking of Le Frog from
    Flushed Away.
    muddy cat, Feb 16, 2007
  16. antonye
    Eddie Guest
    "Your mother was a hamster, and your father smelt of elderberries!"
    Eddie, Feb 16, 2007
  17. antonye
    He's not a 306b-er, he's a very naughty boy.
    ogden, Feb 16, 2007
  18. antonye
    antonye Guest
    "It won't explode there."
    Is that with the same confidence as
    "It will fly out of the tube" ?
    Tbf, I'd run like **** as well.
    antonye, Feb 16, 2007
  19. antonye
    Well, it looks like the gas generator (the bit that fires it out of
    the tube) was a dud, but there's no knowing whether the arming is
    dependent on the motor actually igniting. So it is possibe that the
    motor might still suddenly ignite and quite apart from the rocket
    flare itself, you could have an armed missile suddenly trying to fly.
    As it appears to be an optically tracked device similar to MILAN,
    you'd have what's called a rogue missile, which could go anywhere.
    Not only that, but if the gas generator just suffered a sort of
    hangfire, it could still go off properly, and they do make quite a
    bang.
    Pip Luscher, Feb 16, 2007
  20. antonye
    Owen Guest
    Is it me or is this group acoming so OT the subject or what?
    Did i just post that?
    Owen, Feb 17, 2007
