cb500t parts
Discussion in 'Motorcycle Technical Discussion' started by matt neumiller, Jun 4, 2004.
  1. hello,
    i am working on my 76 cb500t, and need to get two new air cut-off
    valve diaphrams. honda does not make these as a kit, only as an
    entire assembly for $90 each! all i need is the insides. does anyone
    know of a place i can get a set of these or suitable replacements? i
    think 78 gl1000's might work, but am hesitant to order ($20 each)
    without having seen to compare.
    thanx!
    matt
  2. I *think* that with suitable re-jetting you can get away with blanking
    them off. Honda set up the 500T to run very lean (non-adjustable
    needles, small jets) and thus had to fit the carbs with those bloody
    diaphragms in order to stop back-firing on the over-run.
    But needles can be shimmed, and jets replaced....
    I've actually got some used diaphragms knocking around in my garage. No
    idea what condition they're in, and I'm a long way from you anyway.....
    The Older Gentleman, Jun 4, 2004
  3. matt neumiller
    Mark Olson Guest
    http://www.crc2onlinecatalog.com/misc_carb_parts.htm#AIR CUT-OFF
    Has a listing for the '75-79 GL1000, but not for the CB500T, so I
    would assume they will not interchange.
    http://www.motorcyclecarbs.com/
    Claims to be able to get almost any part for motorcycle carbs, have
    you tried them?
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7903809294
    Here's a CB500T carb kit on ebay, which does not include the air
    cutoff valve, however, you might want to email the seller, as they
    appear to have tons of this sort of thing for old bikes.
    Mark Olson, Jun 4, 2004
