CB72 - It lives!
Discussion in 'Classic Motorcycles' started by Mike Buckley, Mar 12, 2010.
  1. Mike Buckley
    Mike Buckley Guest
    I need to ride the thing to see if it's worth pursuing the advance
    timing further I think. Being unable to adjust the front brake so I can
    push the bike with it off and not push it when it's fully on is proving
    somewhat of a challenge at the moment, so no test rides.
    Mike Buckley, Mar 19, 2010
  2. It's been a while but aren't they behind the points plate? I don't see why
    you would have to drop the motor or do anything with the cam.
    T.
    Terry Richards, Mar 20, 2010
  3. Mike Buckley
    Mike Buckley Guest
    They're on the camshaft in the middle of the top of the engine, only way
    to get them is to drop the engine in the frame so the top cover can be
    removed to get access.
    Mike Buckley, Mar 20, 2010
  4. The Older Gentleman, Mar 20, 2010
  5. It's weird that I don't remember that and I'll be damned if I can think of
    any reason to put them there. I'm not disputing your word, it's just plain
    weird.
    T.
  6. Mike Buckley
    Mike Buckley Guest
    Hmm, ta, <watches> the left silencer on mine has been rechromed but
    there are weak spots that are already showing through, mostly hidden by
    the footrest.
    New exhaust systems are $700 from the US.
  7. Mike Buckley
    Mike Buckley Guest
    The points bolt directly onto the head, removing them just reveals more
    of the end of the camshaft, to get at anything else the top covers need
    removing which means dropping the engine in the frame or removing it
    completely. When the top cover is removed you can see the cam lobes, the
    tops of the valve springs and the advance mechanism which I think is
    around the same place the two parts of the camshaft are locked together.
  8. Mike Buckley
    Rusty Hinge Guest
    If you don't need a genuine one, there's a chap near me (S. Norfolk) who
    will make you stainless steel ones - pipes too.
    Rusty Hinge, Mar 21, 2010
  9. Mike Buckley
    Mike Buckley Guest
    A closer look at the one on ebay shows it's worse than the one I've got.
    Definitely interested in stainless ones. Can you pass on his details
    please? toastyhamster at hotmail dot com
    Mike Buckley, Mar 21, 2010
  10. Mike Buckley
    Rusty Hinge Guest
    Check
    Rusty Hinge, Mar 23, 2010
