CBF500 battery gel?
Discussion in 'UK Motorcycles' started by Tim B, Dec 9, 2008.
  1. Tim B
    Tim B Guest
    Need to charge the battery in the CBF500. Is it likely to be gel? The
    charger does car & bike, but requires you to select if it's gel.
    Regards,
    Tim
    Tim B, Dec 9, 2008
  2. Tim B
    wessie, Dec 9, 2008
  3. Tim B
    Tim B Guest
    Thanks for the help, it was bit of an urgent request and I'm still
    learning a bit about batteries. I'd done a search and it came back with
    several after market gel batteries. But didn't find anything about the
    original other than it was a sealed unit. I didn't know if they were
    interchangeable. Just been out and got the charger and it uses
    different terminology than advertised (standard and sealed). Looks like
    I'm not in work tomorrow anyway, so panic over.
    My guess at this point is sealed = gel.
    Thanks
    Tim
    Tim B, Dec 9, 2008
  4. Tim B
    @newsfe24.ams2:
    Not necessarily. Most sealed batteries on bikes will be gel types, as they
    are cheaper. There are other sealed types e.g. the AGM (absorbed glass mat)
    type I have on my bike. http://en.wikipedia.org/wiki/VRLA tells you why
    sealed is a bad adjective for batteries and explains the differences
    between AGM & gel.
    If your battery is low then any charger will top it up. You only need a
    specific charger for a particular type if you are dealing with a deep
    discharged battery.
    Some bedtime reading http://www.batteryfaq.org/
    wessie, Dec 9, 2008
  5. Tim B
    Tim B Guest
    Thanks for the URLs, I've had a quick read and definitely book marked.
    The bike is back up and running after a brief 2-4hr charge. Looks like
    the negative screw had loosened 50% along its thread. Guess this would
    have reduced the charge getting through to the battery. These things
    are always easier in '+' temperature and daylight.
    Regards,
    Tim
    Tim B, Dec 10, 2008
