Experience has taught me to install a voltmeter on motorcycles. During an extensive trip I noticed low voltage. A Honda dealer mechanic agreed there was a problem but thought the system would get me home (it did, barely), but I have a basic question: How do you determine alternator output? The regulated output is speced at 12.6 to 15.0 volts at 15,000 rpm. That is quite a range and correct output would depend on load and battery condition, etc. Is ther no way to load the alternator and check output? The shop manual has you check the regulator/rectifier by the resistance of various contacts, and specifies only two specific branded voltmeters can be used. The alternator is checked by an ohm meter as well. Is there no way to load this alternator and then check output voltage? Also, I can find no specification for alternator output (wattage). Can anybody help? Thanks.
